one or two pallet jacks will do the job. And if your dragging it on wood, onto the trailer, grease the wood. We just got a hugely heavy machine out of a small space with 2 of them
Depending on the weight of the machine, i might consider jacking it up one end, backing the trailer under it, connect and tighten your winch, take both jacks to the back end, jack it close to level, then pull it with the winch,
What do you think it weighs, i would say bewteen 750kg to 2500kg,
The Following User Says Thank You to george uk For This Useful Post:
09-04-2014 #2
09-04-2014 #3
That sounds a little light and I would guess 1000Kgs would be more realistic. Friend and me wounce moved a much heavier machine (Wadkin 6 headed spindle moulder) up and over a 400mm high wall onto similair trailer with just 2 trolly jacks 2 Planks of wood and scaffold tube. . . . With levers and rollers you can move anything Just like the Egyptians. .
Eddy current here you go if it helps you sleep better. .Last edited by JAZZCNC; 09-04-2014 at 08:55 PM.
10-04-2014 #4
BUILD LOG: my router build - advice needed
By thomashomer1986 in forum DIY Router Build LogsReplies: 10Last Post: 02-12-2013, 11:45 PM -
Chinese 6040 CNC Router Advise Needed
By Bob Hepple in forum Chinese MachinesReplies: 24Last Post: 27-11-2013, 12:00 PM -
RFQ: laser or router cnc needed
By ktc in forum Projects, Jobs & RequestsReplies: 0Last Post: 09-08-2013, 12:08 AM -
RFQ: help needed to make cnc machine maybe 2-3 and will pay
By scnc in forum Projects, Jobs & RequestsReplies: 10Last Post: 22-11-2012, 12:31 AM -
BUILD LOG: New cnc router build looming, advice needed
By Mad Professor in forum DIY Router Build LogsReplies: 5Last Post: 06-11-2012, 08:12 PM
