Thread: Work hold down
    This is how mine turned out, it uses 40 x 16mm T slot and some home made clamps and knobs with 6mm threaded rod of varying lengths.
    Dark patches on the bed are a result of the leveling process on birch plywood ( 2 x 18mm sheets)
    The layout looks fancy but I ordered 4 x 1m lengths of T slot with the initial idea of having all 4 spaced out but parallel to the long axis. I didn't like it after trying to clamps some wood down so changed it to what you see now, the best layout I could get without ordering more T slot.
ID:	12139Click image for larger version.
    Looking good
  1. mini hold down clamps
    By Daedelus in forum Tool & Tooling Technology
    Last Post: 05-03-2014, 09:42 PM
  2. Hold down solution
    By jonbabbz in forum General Discussion
    Last Post: 11-10-2012, 08:21 PM
  3. Hold down clamps, what do you use?
    By Web Goblin in forum Machine Discussion
    Last Post: 14-04-2012, 11:45 PM
  4. Custom Vacuum Table 'Hold Down' System - piping/valve advice
    By FlightCaseCo in forum Machine Discussion
    Last Post: 16-01-2012, 06:56 PM
  5. Workpiece hold down by glue
    By Robin Hewitt in forum Machine Discussion
    Last Post: 30-09-2010, 08:22 PM
