Thread: Safe Z Speed
    sorry, not sure how to do that
    Hi dudz,
    You would just paste the code into a text file and then attach that file to your post, or you could wrap your code using "code" tags and this presents it a little better in your post, have a look above as i've done that for you.
    .Me
    dudz's Avatar
    Lives in Dunedin, New Zealand. Last Activity: 09-02-2025 Has a total post count of 295. Received thanks 2 times, giving thanks to others 79 times.
    I was hoping I could set the G0 moves alot faster than the Feed rates
    Swedish Storbro Luna - 3 axis CNC mIll - 250 - 2500rpm / 1.1 tonne
    dudz's Avatar
    Oh thanks lee !
    G0 moves are done at the Velocity set in motor tuning. G1 moves are done at the commanded Feed rate ie G1 X36 F600.
    If you have X and Y axis set at different velocity in motor tuning then any blended moves like G0 X300 Y50 will be done at the lowest velocity or some derived velocity based on both so both axis arrive at same point together.
    If each axis moves separate then any G0 move will be done at the velocity set for that axis.
    What is the velocity for each axis in Motor tuning.?
  5. #15
    dudz's Avatar
    X = 4000
    y = 4200
    z = 2000
    Just tried the famous aztec calender "cutting air". The fast feed G0 travels at 1000 units per min
  6. #16
    Sounds like you have feed rate override (FRO) set to roughly 25%.
  7. #17
    dudz's Avatar
    Which screen is that set in please ?
  8. #18
    dudz's Avatar
    The feedrate while milling is OK
  9. #19
    Which screen set are you using.? If it's standard 1024 then see pic and marked circles.
  10. #20
    dudz's Avatar
    I ran the aztec again. The X and Y travels around 1500 units/min while cutting but as soon as the Z retracts to go to the opposite side, it runs at 1000.
    Using Big Tex screen. It states 100% for FRO and Rapid FRO is not shown. I will try in the standard 1024 screen in a minute.
  1. Need to slow down a signal due to Safe Torque Off alarm
    By corkcnc in forum General Electronics
    Last Post: 04-06-2014, 11:35 PM
  2. HSM Advisor - High Speed Machining feed & speed calculator
    By magicniner in forum CAD & CAM Software
    Last Post: 20-01-2014, 12:57 PM
  3. Z safe in g code question
    By Fivetide in forum CAD & CAM Software
    Last Post: 20-02-2013, 08:00 PM
  4. Speed control
    By Saracen in forum Spindles & Drive Motors
    Last Post: 29-12-2012, 02:18 PM
  5. Safe Z Arghhhhhhhh!! Whats going on!
    By AdCNC in forum Machine Discussion
    Last Post: 18-08-2009, 05:15 PM
