Hi, I do quite a lot of routing with 3.2 and 6.3mm HDF/MDF. I mainly use 2mm PCB endmills and run the spindle at 2400+ rpm and a feed of about 2M/min. I do sometimes (if in a hurry) run at 3or4m/min, but worry a bit about tool breakage. at 2M/min the tools last for ages.
18-08-2014 #2
18-08-2014 #3
19-08-2014 #4
Yes, thanks Clive, of course I did mean 24000rpm. the slowest my spindle will run is 1500rpm.
I always cut HDF/MDF in a single pass, but only cut up to 9.2mm. For the 9.2mm I use a 3.172 cutter. G.
18-08-2014 #5
Thank you Geoffrey for your input.
I'm looking to use mainly 4mm MDF for making shapes, letters and the like for craft workshops, customers and sell on the internet.
I'm assuming at the 24000 rpm at 2m/Min I can get away with one pass.
Using Vectric V Carve Pro I am leaving "Tabs" to prevent breakout of the shape within the main board as it's cut. Half depth and 2mm long at 3 or 4 points around the outside where the nibs after the shape is pressed out of the panel by hand can be sanded off with a bobbin sander to finish
The faces I hope to use a Jet occillating drum/belt sanding machine to just kiss off any rough edges, but have been advised that there is a rotary triple wire brush machine which provides good results without lining or gouging. Yet to find that machine as I'm not sure of the proper name.
Thanks to the other guys that have replied as well, I am working my way through various tables to find out about speeds and feeds, depths and types of cutters as well.
If you can't fix it with a hammer you've got an electrical problem !
Acrylic Cutting Help
By Tenson in forum Machine DiscussionReplies: 26Last Post: 08-11-2016, 08:15 PM -
Advice on Mammoth CNC Router Build - Steel Framed - 2440mm x 1220mm cutting area!
By Wejjmeister in forum Gantry/Router Machines & BuildingReplies: 87Last Post: 03-01-2016, 12:45 AM -
Cutting Ply/MDF
By Leadhead in forum Wood Finishing Tips & TricksReplies: 3Last Post: 02-10-2013, 01:59 PM -
Cutting HTD pulley(s)
By Jonathan in forum Metalwork Project ShowcaseReplies: 2Last Post: 11-12-2012, 07:19 PM -
Gear cutting
By John S in forum CAD & CAM SoftwareReplies: 7Last Post: 03-10-2010, 07:55 PM
. ..Clive
