    No problem with that, wouldn't put the broken bit back anyway, just build the whole end up with filler weld, 15 minute job.
    John S -
    A generous offer, OTOH I am more than a bit impetuous and an M8x40 looks rather inviting. If I can close the gap I could be up and running today :naughty:
    I have a spell in the dentist's chair at half past ten, a good opportunity to cogitate
    M8x40 did the trick, gap closed, put an arrow on the pic in case you couldn't see where it was
ID:	552   Click image for larger version.
ID:	553   Click image for larger version.
  4. Quote Originally Posted by Robin Hewitt View Post
    Did you drop some loctite in the gap before closing?
    Because if it gets the faintest jiggle it will never close that sweetly again :nope:
    Good idea, but then I'd have had to clean off the RTD and I was rather enjoying putting it together :naughty:
    If I take it off I promise to Loctite it
    Kip, I don't know how it compares to driving the handwheel because I've never tried that. If I had to guess I'd probably plump somewhere between amazing and freakin' miraculous
    Curious.
    I wound up the feed rate on that hybrid stepper and it would do 18mm/s but clacked out at 20 mm/s
    I disconnected the Y axis to get some spare Amps then switched the hybrid peak current from 1.9A to 4.2A peak.
    Wouldn't do 18 mm/s anymore :nope:
    Possibilities...
    The cable on the Z is altogether too long and it's having problems controlling the current.
    The stepper driver can't actually cope when you increase the current.
    I imagined it :heehee:
    So, any ideas what driver/PSU combination I need to shop for?
    However, 18mm/s is a lot better than I had before so I made new plates to fit them on the X and Y. Stuck a fanciful strain relief bracket on the X so I can bolt the flexy trunking to it.
  1. Haighton Major
    By BillTodd in forum Milling Machines, Builds & Conversions
    Last Post: 14-05-2022, 02:17 PM
  2. WANTED: Conect Minor or Major CNC Milling Machine Wanted
    By stevy123 in forum Items Wanted
    Last Post: 24-08-2011, 10:35 AM
  3. CONVERSION: Buget Warco Major 5 axis conversion
    By Tweaky in forum Conversion Build Logs
    Last Post: 07-10-2010, 04:26 PM
  4. Warco Super Major Mill 3 month old
    By grimreaper in forum Milling Machines, Builds & Conversions
    Last Post: 18-07-2010, 02:50 PM
  5. NEW MEMBER: Warco super major mill
    By ste64 in forum New Member Introductions
    Last Post: 26-05-2010, 04:27 PM
