A pair of 2flute 6mm cutters arrived. Very cheap and came in 4 days from UK not HongKong. http://www.ebay.co.uk/itm/190984562714 price was only £1.69 last week ! I've got some more expensive ones as well coming from china, comparisons will come in due course.
So I disconnected Z, and that allows me to drive around in X and Y.
Feed 1200mm/min. 6000RPM.
First I did full width passes along the top at about 1mm doc > all fine.
Then I sidemilled the endface with doc 3mm stepover about 1.4mm. Fine conventional but when I tried to climb mill on the way back I got a loud vibration.
That made me panic and I hit a key (aiming for reverse!) and instead took a cut at full width 9mm doc. That too made a noise but nothing broke.
I'm pretty pleased. Acetal is the easiest plastic to work with, and I'm all for making life easy. These feeds and speeds are plenty for the small pieces I have planned.
I'll probably go back to 16 microsteps giving a max feed around 2300 as I don't think I'll be needing 4700 mm/min.
Hoping my replacement drivers arrive soon so I can do some CNC.
