    ok thanks ill try that. im rite in thinking at the moment they are both set to on. so all i need to do is switch k2 down on all three . Then change the steps per to 80 . I do have 3 of these i could try and see if its any better if that dose not work .
    http://www.ebay.co.uk/itm/EU-Free-Sc...item338efc0758
    Lives in Marple Stockport, United Kingdom. Last Activity: 10 Hours Ago Forum Superstar, has done so much to help others, they deserve a medal. Has a total post count of 3,348. Received thanks 620 times, giving thanks to others 90 times. Made a monetary donation to the upkeep of the community. Is a beta tester for Machinists Network features.
    Quote Originally Posted by amxen View Post
    The problem with these motors in the inductance is far too high. Check these out:- http://cnc4you.co.uk/resources/60BYGH301B.PDF and see the difference, the motors you have require a much higher voltage to drive them. I would be selling them and getting some with lower inductance. ..Clive
    Now you have lost me with inductance. i got this kit awile ago with the plane to make my own cnc but ended up buying one . this is the kit i have spare
    http://www.aliexpress.com/snapshot/6104230003.html
    but i was thinking i could just use the stepper motors if the ones im using arnt up to it. So is this not the case ?
    Are you saying my power supply is not upto the job because if thats so could i not just swap it out for the 36v one i have ?
    On the picture I looked at it says on the terminals 24V, Gnd, so are you sure it can be powered by 36V ? if it can then it might be a good idea to try the other supply.
    I agree I have a feeling that those drivers are only OK up to 24V So unless you like magic smoke don't go higher. Clive
  1. New 6040 owner looking for advice from others with a chinese 6040/3040
    By itsmillertime in forum Machine Discussion
    Last Post: 14-10-2019, 08:30 AM
  2. Chineese 6040 problems
    By Kendrick57 in forum Gantry/Router Machines & Building
    Last Post: 18-10-2015, 10:52 PM
  3. Chinese 6040 from uk eBay seller x axis problem
    By CommanderKenyon in forum Gantry/Router Machines & Building
    Last Post: 20-02-2015, 02:13 AM
  4. my 6040 experience (yeah, and problems) so far
    By jimbo_cnc in forum Machine Discussion
    Last Post: 07-10-2014, 11:26 AM
  5. Chinese 6040 CNC Router Advise Needed
    By Bob Hepple in forum Chinese Machines
    Last Post: 27-11-2013, 12:00 PM
