Thread: Tiddy CNC.
21-09-2014 #2
21-09-2014 #3
Thanks Chaps, I'll do some documentation tonight. I may have muddied the waters a little, the first issue was the closing door, it was weird and I couldnt see anything, so I removed the chassis connector and it was resolved, I'll post pictures to describe that one better. The second issue (possibly realted) seems to be just when the VFD spins up the spindle as I can have the VFD on spindle stationary and the comms stay up. The VFD is the standard Huanyang variant from China, nothing changed from default, it does make some noise on start-up, the water cooling is active but I guess as its indoors and I'm usually tinkering in the early hours, luckily our neighbour is on holiday :) The reason I'm on USB is the board doesent have the Ethernet module on it, I'll try to source one shortly. It does feel noise/interference currently but frankly the control box was very prototypish anyway with lots of connectors across different faces of the box and the door used becuase I ran out of space, I was planning to move to a larger box and possibly mount the vfd in there also. Anyway, thanks for the ideas, I'll document where I am, look at the ethernet module and see about a bigger box shortly. Three quick questions though..
1). Do folks power the VFD, PSU's and all other CNC stuff (not including PC) from just one 13A wall plug, I'm using the VFD on its own plug right now.
2). For the ethernet SS, do I need to add a router or switch between the SS and PC or will a cross-over cable generally do between them?
3). I would really like to mount the control box on the frame, I've read comments about vibration etc, is it really a bad idea or do some folks find it works ok, it would make my cabling neater and the whole machine would be more compact.
Cheers. Tony.
21-09-2014 #4
If you have mounted some parts on the door have you in fact grounded the door to the box, or are you just relying on the hinges for the ground? ..Clive
21-09-2014 #5Spelling mistakes are not intentional, I only seem to see them some time after I've posted
The Following User Says Thank You to EddyCurrent For This Useful Post:
21-09-2014 #6
Thanks to Gary @ Zapp who answered a query today, the PLCM E3 card I am using also support's ethernet, I've been assuming that it didnt since the there appeared to be a daughterboard on the SS literature that isnt on the card I have.I guess the Rev 2 of the SS that I have didnt need it. I have comms to the SS now, I had a crossover cable adaptor spare so thats working now :) I can jog so thats working fine. The VFD is soundling like my very own Rols Royce Trent 900 turbo fan & I can jog so no lost comms :) :)
Thanks for the feedback Eddy, until I upgrade the control box I'll stick to a seperate wall plug for now. Time to read the VFD manual now and find out how to not have it spin so fast it wakes the neighbourhood. Thanks again.
21-09-2014 #7
Ok first let me just clear up something because it becomes confusing for others reading this.! You don't have a SS this relates to a particular Brand name of Motion control card called the Smooth stepper shortened to SS or ESS for the ethernet version.
You have PLCM E3 which is still a motion control card but not to be confused with the SS.
Now what breakout board do you have because the PLCM E3 doesn't have spindle speed control directly so for this you'll need either external spindle speed control board or a breakout board with one built into it.
If you haven't set up the parameters in the VFD then don't go trying to make it start else you'll possibly do it some damage if the parameters are set wrong.
After setting intial parameters like Voltage, amps etc then if you want to control it thru G-code and the control software then you'll need to set more parameters in VFD so can be controlled from an external source. Also along with this you'll need to set outputs and spindle settings etc in Mach3.
Do a search on the forum and you'll find the settings and parmeters to change.
21-09-2014 #8
Thanks Jazz, you're right, I meant the generic, it is as you say an PLCM E3 from Purelogic, a Russian company. I'm using the Zapp ZP5A-INT breakout board, I'm not planning to try and control the spindle speed using that but I do have a USB dongle that supports RS485 that I've read will work for speed control. We'll see, right now as you say I've got to explore the VFD manully and get that going, with perhaps a little less noise.
