Thread: Quite an Unusual one
damn! was sure I'd sussed it. Very confusing.
Why do they say large areas cure faster? does it generate it's own heat for curing?
If there was room for another 3mm pour on top of the old one, I would be tempted to do that.
Out of interest, what is the deepst and shallowest depth in the 2 rails on the previous pour?
Interesting you mention fixing aluminium plate to gantries and surfacing them. I had that thought today, someone should be selling ready made flat side gantries.
15-10-2014 #2
Theoretically more volume epoxy cures faster, cause the heat can not escape so fast, heating the mixture so then all cures faster.
WS 105-209 gives 1h gel time, though i found that 1h 1/2 is still ok, up to 2h when is okeyish almost but still not unusable. That at 22C .
As i carefully welded the frame and a couple of times leveled the structure, the depth is 4-6mm . If i do it next time all will be steel, dam 10x10mm welded , channel >45mm wide/cause will hit the bearing blocks other wise. perfect will be 8x8mm bar. Clean, fast, beautifull. No finishing needed and most of all on such a big table water can be applied earlier so level it perfectly. Before pouring i mean.
They sell mounting straight edges but 3m one willbe 3000euro. Of course then epoxy can be applied below and then the straight edge mold it pushing it down. Then remove and do it at the other side.
So i took out the epoxy. Will have to do it again it seems. I almost have it clear. Will update here, so you tell me what you think, meanwhile will search for somebody around who builds boats or something and knows about epoxies first hand, to see if help can be obtained.
What i came till now is very simple. Extend both rails both sides 30cm each, then bridge them. When dry cut the extra 30cm each side and hope for the best in the center :-). Have to contemplate it further but i feel that this will work. And apart from this i will know for sure if i can build one day 5x10 foot CNC :-) with epoxy. Or not.
15-10-2014 #3
Maybe a bit off the wall but have you thought of using plastic tubes between the two sides rather than bridges - these could be shut off with clamps once the epoxy has levelled. it would be an easy job to 3d print the necessary bits.
15-10-2014 #4
Is there an accelerant for epoxy same as that for super glue ? maybe that could be used to make the bridge epoxy go off quicker ?
15-10-2014 #5
Syliavski I am sure you will find the solution. Your mind is sharp so I don’t worry. The only think I want to say is that some times we stack and we become maniac with some specs off the machines that we build. I would be the last one to talk here as I haven’t finished a machine yet. That doesn’t mean that I don’t have an opinion. So I think that the solution to your problem is more than obvious. It is #1 that you suggest. Go on with shimming. As I have read here in the forum many people use only shims. Why it would be such a big problem for you to use shims only in a small area ( near the bridges). Also have in mind that all these people who have already use the epoxy method, may never compare the straightness of the epoxy against a straight edge. The first introduction of that method that I saw here in the forum was Jonathans machine. But this machine ( as your first one ) was smaller. The scale is very important. Even a 3000mm straight edge may have (0,01%=0,3mm loss at accuracy ) I don’t want to introduce my self as the clever who knows everything. Most of the people here in the forum wouldn’t imagine the problem that you come up against. The only positive is that you give us a good lesson unfortunately by spending 200 euros. This is life. This is they way we learn, by making mistakes. No one could blame you. I think go on with shims is the best way to continue. For sure there is a solution about the epoxy method at this scale but if you want to find it you must pay. The most common characteristics that the DIYselfers have I think are stubbornness and persistence. We think that we can solve any technical issue and that make us some time loose time and money. It is useful some time to make a step back, see the things more clear and then go on again. I am no talking as an expert or as an experience constructor, I am talking as a friend ( even if I have never see you, you have helped me and that gives me the right to consider you friend ). Keep going
The creative adult, is the child who survived
15-10-2014 #6
@ba99297, very nice post
I think we do know most of the answers it's just we don't have access to the right (hugely expensive and massive) machinery. For example if the frame could be put under a huge surface grinder the job would be done without epoxy and super accurate.
It also makes me wonder what happens when the frame is stood on an uneven floor, okay it's very rigid and the adjustable feet would be set as accurate as possible but would the frame move over time ? and by how much ? 0.1 mm ?Last edited by EddyCurrent; 15-10-2014 at 08:46 PM.
15-10-2014 #7
Just wondering if this might be worth experimenting with.
http://www.ebay.co.uk/itm/SP300-EPOS...item43cfc05850
It's almost like water so could contain a lot of solvent,but might be worth a try, i use it for sealing wood patterns and it takes about a day for any remnants in the mixing container to set solid, how does it compare price wise with the West Epoxy.
