Thread: What 'decent' Milling machine?
16-05-2015 #2
Forget PlanetCNC for retro fitting again it's a toy. You wan't ethernet for serious machine USB is rubbish and unreliable IMO.
Denfords are still toys but very good toys.!! . . . . . . By the way the Denford in Dewsbury you show I know the guy who Converted that to Mach3. He actually works for the Company who's selling it.
If your planning on milling aluminium then look towards a machine with high spindle speeds 5K is minimum 10K + better.Last edited by JAZZCNC; 16-05-2015 at 10:28 AM.
16-05-2015 #3
Thanks again all. Problem is no 3 phase at home. I could run a VFD for the spindle. Cant help but get the feeling Im biting off more than I can chew :-(
Mmmmm. I dont know enough about whats good and what bits are good and the potential money pit is big I think, especially if I need to start to retrofit parts.
16-05-2015 #4
It's not difficult but does require some knowledge and plenty of research before commiting.
IMO all the machines you have shown so far are cheap (with exception of Denford) chinese imports. They are badged up with someone elses name on but all the same low quality machines.
I think you will be disspointed with the results and you will in the end up either chasing away problems they have and wasting money doing so or selling on.! . . . All cases you'll still Blow money.!!
Old machine and retro fit will serve you better in long run. Also You'll more than likely sell it for more than you payed if you ever do move on or upgrade.
To be honest for your needs with aluminium and plastics which requires higher spindle rpm/feeds I'd build a very strong Fixed Gantry machine and put the money into using good components and ATC spindle before waste on those Chinese Import Milling machines.
The mills will always perform below par for cutting aluminium and plastics compared to strong machine built and spec'd for the task.
Retro fitting a old machine with a high RPM spindle 8k plus would be only choice between building or buying. No way would I consider Small mill for cutting aluminium unless it had high rpm spindle and used Linear bearings.!!
16-05-2015 #5
Thanks. I did build my own machine before. It worked 'OK' but not sure Ill do that again. Here is a vid of it cutting a plastic gear with a 1mm high speed endmill.
https://www.youtube.com/watch?v=t_jXTrO0rok
I could not get the rigidity I needed and making centre holes (on a different gear) proved almost impossible.
16-05-2015 #6
Well what do you expect if you built it out of spagetti.!! . . . . . I'm talking about properly built machine built with substantial materials and correctly done.
If done properly then it's not difficult to build a machine that will do everything you need and do it much better than any cheap chinese import mill can.!
The difference between th 2 bridgeports is the series. MK1 & Mk2 They look like this.
16-05-2015 #7
16-05-2015 #8
Going to be honest now and you may not like it.!!
It appears to me that you don't have enough machining experience yet to justify laying out big money on machines when you don't even know what you require.
For instance the best mill or CNC machine won't make relocating your part any more accurate if you don't know how to do it.!
The fact the machine you built doesn't make the grade is purely down to poor weak design and choice of materials. The fact you can't relocate on centre is down to your low level of experience.
If you'd made fixture jigs to hold your work and indexed to a known fixed reference point then it's easy.
But your machine is so weak it will flex like jelly so this can't happen. Trying to re-locate centres without a fixture is hard at best of time on any machine and requires accurate devices to help. So no matter weak or Strong if you haven't got the abilty or the equipment then you will always struggle.
Your weak build is to blame for low part accurecy for sure but has nothing to do with reloctating and no amount of strength in the machine will helps this as it's down to you to come up with ways to fixture.
Properly built DIY machine which uses good components will easily do what you want.
FOR SALE: 240v decent electric filter
By DrNik in forum Items For SaleReplies: 3Last Post: 16-03-2015, 12:30 PM -
WANTED: cnc milling machine
By bigred5765 in forum Items WantedReplies: 14Last Post: 25-04-2014, 11:08 PM -
eBay: Looks a decent little machine
By EddyCurrent in forum Items On eBay UKReplies: 13Last Post: 12-09-2013, 04:55 PM -
A decent little (PCB miilling) Chinese machine...
By HankMcSpank in forum Machine DiscussionReplies: 5Last Post: 18-06-2013, 06:59 PM -
First CNC milling machine help
By newtoid1986 in forum Milling Machines, Builds & ConversionsReplies: 0Last Post: 05-09-2011, 10:06 PM
