    Jon.'s Avatar
    Location unknown. Jon. Last Activity: Has a total post count of n/a. Referred 6726 members to the community.
    Im with jess on this one, usb is far more reliable.
    I run both my machines with uc300's from a laptop. it never looses connection, has an excellent 100khz buffer and has been left on for over a week in the past with no issues.
    I also have a wired network with multiple routers tried over the years and they all failed from time to time. I know not the same but doesn't give me much faith.
    Quote Originally Posted by Jon. View Post
    II run both my machines with uc300's from a laptop. it never looses connection, has an excellent 100khz buffer and has been left on for over a week in the past with no issues.
    See this is the point.!! . . . . I've used the uc300 and it was fine. Untill you turned some high frequency device on near by then it would freakout. (In the USS case next Room.!!)
    Yes it can be said it's the Cards fault not USB protocol but this doesn't happen with Ethernet driven devices I've used. They handle EMF and such crazyness much better in my experience.
    I'm not into communication and all that goes with it. But I am into CNC and all that goes with that and I know thru experience that Ethernet is better than USB when it comes to running a CNC machine using Mach3..!! . . . Which is what started this whole Hang bag stuff in first place.!
    It's just some people have to twwist words and things around to suit there own Ego's!!
    Jon.'s Avatar
    Both Ethernet and usb are digital so noise is likely to effect both if large enough, i have my uc300 running an inch away from my 2200w vfd and two inches from a honking great 55v toroidal transformer without issue so sounds like your noise may have been in your power supply, were you using ac filters? either that or there was something massively wrong happening in the next room.
    Lives in East Lothian, United Kingdom. Last Activity: 19 Hours Ago Forum Superstar, has done so much to help others, they deserve a medal. Has a total post count of 2,990. Received thanks 374 times, giving thanks to others 9 times.
    I suspect Jazz's source of interference was a HF Plasma Cutter, or HF TIG welder, both of which will produce and emit interference that will far exceed anything a properly wired VFD will.
    If you get the chance, you might want to try firing one up next to your machine, and see if it still remains as stable, as there's nothing quite like a few hundred volt high frequency unsheilded arc to highlight the slightest deficiency in your shielding/grounding/power filtering/communications.
    Jon.'s Avatar
    Be interesting to find out. Though a grounded metal enclosure around the controller, which should be general practice, would most likely solve the issue. If it didnt id be suprised and very much suprised if the etherenet controller wasnt effected by such levels of noise.
    It probably would be, however Ethernet is far better at handling and recovering from noise problems, as it can handle and resend lost data packets, whereas USB doesn't have that capability. I do suspect USB comms could be improved to handle these situation better, but it'll add cost, complexity, and processing overheads.
    I know from various USS discussions, Greg struggled to fit all functionality into the USS, so I suspect it was having to do the bare minimum to handle communication. When it came to the ESS, Greg used a larger FPGA, and I do suspect there may be more going on within it to handle communication problems.
    I also suspect other manufacturers have looked at the issues from the USS, and implemented strategies to better handle communication faults, as other good quality USB controllers don't seem to suffer from anywhere near as many communication faults.
    You have to remember USS was the first successful USB external motion controller for Mach3, and it did achieve a lot, however I do think it's probably time to retire it, or at least update the hardware.
    All the machines I build use Metal Enclosures and believe me it doesn't help much. Ethernet isn't affected nearly as much and better Motion devices like CSlabs it doesn't affect at all.
    I'm just currently testing the Pokey's 57CNC which uses Ethernet and it survived the Tig test but then funnily enough it threw a little wobbly by E-stoping when I was using the Mig welder.? It's behaved since thou so could have been that and the fact i'm using the 5V signal for E-stop. (plus it's rough wired on the bench)
  1. USB/Ethernet controller for Mach3/4 advice
    By paulus.v in forum Control Hardware & Systems
    Last Post: 17-02-2015, 09:37 PM
  2. CSMIO/IP-M vs Ethernet SmoothStepper (Begone foul parallel port!)
    By Greeny in forum Control Hardware & Systems
    Last Post: 14-11-2013, 11:59 PM
  3. USB and Ethernet Mach3 motion controller PLCM-E3
    By Purelogic R&D in forum Manufacturer News
    Last Post: 29-12-2012, 09:38 AM
  4. Pros and cons of climb milling in wood
    By Richie in forum Wood Finishing Tips & Tricks
    Last Post: 14-06-2012, 05:09 PM
  5. Types of Ballnut and preload, questions - pros & cons ?
    By Jon S in forum Lead Screws, Nuts & Supports
    Last Post: 16-01-2012, 03:39 PM
