Yea, the estop has nc marked on it. If I adjust to the mach3 settings to low active it just says e stop requested even though the led for estop only lights up when the estop is pressed. I haven't got a clue what's going on.
05-12-2015 #2
Thats what it should do.? The LED should only come on when E-stop is pushed in. It's informing you that an E-stop occured.
When you release the E-stop button the LED goes OFF and Mach will then allow Reset.
NC means the Circuit is closed before the E-stop is pushed. So when pushed the Input you used for E-stop is pulled Low or high and that's why you use Active Low or high mach knows when that input goes Low or high and E-stop is active. The LED comes on to inform you.
This does depend on your BOB Input some are Pulled High or Low with pull up/down resistors in which case you just change the active state to match.
Don't trust the markings test it.! . . . When released you should get continuity between terminals if it's NC. When pushed there should be none.Last edited by JAZZCNC; 05-12-2015 at 10:08 PM.
05-12-2015 #3
That's the problem, it wont allow Reset when set to active low and when the estop is off(not pressed) even though the diagnostics say the estop isn't active. I can Reset when I set active high but this is when the button is pressed in, which is wrong?
Haha, I'm rubbish at explaining things.Last edited by amd7000; 05-12-2015 at 10:43 PM.
05-12-2015 #4
Sounds to me like you may be using the wrong Input number or not set the port number or something then because mach isn't seeing the pin state change.
If you had the correct pin number then toggling the Active state would work no matter if your inputs used pull up or down resistors.
Not using the correct pin/port number or a Blown input is the only thing that would do this. The fact Mach resets when you toggle Lo active just means your tricking mach into thinking E-stop is there. It's basicly watching that input to go high which never will because you have the wrong Input number or it's dead.!
06-12-2015 #5
I had a look at the Zapp website and the documentation there doesn't mention the estop pin. However I then loaded up the .xml file provided and ran Mach3 with it and it is set to port 1 pin 10 active low is a red cross.
So I have doubt that you are using the right input pin.
RobLast edited by cropwell; 06-12-2015 at 02:24 AM.
The Following User Says Thank You to cropwell For This Useful Post:
06-12-2015 #6
06-12-2015 #7
I know that Dean, but if you look at the Zapp site, there is a manual for the board. It shows a picture of the board and one input has a printed label 'ESTOP' with an arrow pointing to it saying P15. However the .xml file Zapp supply uses pin 10. This does rather suggest to me there is something awry. I would certainly try changing Mach3 to use pin 10. In the Zapp copy of the Chinglish documentation it says use Mach3Mill profile, which is also pin10 for Estop.
I also think that Mach3 diagnostic screen could have better labelling of the LPT indicators.
Cheers,
RobLast edited by cropwell; 06-12-2015 at 12:22 PM.
AM882 works with Protune - but not with the ZPA5-INT BOB
By badgerman in forum Motor Drivers & ControllersReplies: 19Last Post: 01-09-2013, 09:44 PM -
TOSHIBA THB6064AH Updated Active IC
By lihaijiang in forum Manufacturer NewsReplies: 1Last Post: 09-04-2012, 03:43 AM -
Well it looks like I have to bite the bullet (solid works)
By Kai in forum SolidworksReplies: 9Last Post: 03-04-2011, 01:52 AM -
How Rotary Broaching Works
By steve3d in forum Tool & Tooling TechnologyReplies: 0Last Post: 18-01-2011, 03:17 AM -
My CNC WORKS...
By emboss.shop in forum Metalwork Project ShowcaseReplies: 0Last Post: 30-09-2009, 06:04 PM
