I know that Dean, but if you look at the Zapp site, there is a manual for the board. It shows a picture of the board and one input has a printed label 'ESTOP' with an arrow pointing to it saying P15. However the .xml file Zapp supply uses pin 10. This does rather suggest to me there is something awry. I would certainly try changing Mach3 to use pin 10. In the Zapp copy of the Chinglish documentation it says use Mach3Mill profile, which is also pin10 for Estop.
I also think that Mach3 diagnostic screen could have better labelling of the LPT indicators.
Cheers,
RobLast edited by cropwell; 06-12-2015 at 12:22 PM.
06-12-2015 #2
Yes i see what your meaning now Rob but I wouldn't put much stall in that because they could have just used Pin for E-stop at the time.?
This is the problem Chinglish manuals they leave you guessing but in this case it's easy really just keep entering pin mubers between 10 -15 in mach's E-stop Input.
Amd What pin number did you have in entered.?
06-12-2015 #3
07-12-2015 #4
Sorry for the late reply guys. Been in bed with a dodgy chest infection, no energy to do anything, i'm sure its the damn ecigs.....
I set the estop to port 1 and pin 15 as stated in the manual. It was set to pin 10 in the first place when I loaded the xml and before fitting the estop. I cant remember if I tried it with pin 10 first. Will try when I'm feeling better. Thanks for the help. Really appreciated.
07-12-2015 #5
Just had a thought - there is a program called LPTTEST you can download for free, it tells you what the BoB is sending to the machine, so you will know what pin Estop is on and what state it is in when normal / pressed. Then you will know what to set in Mach. I built a tester some time ago with Leds and an input socket and a output socket - but I can't find it now.
Cheers,
Rob
AM882 works with Protune - but not with the ZPA5-INT BOB
By badgerman in forum Motor Drivers & ControllersReplies: 19Last Post: 01-09-2013, 09:44 PM -
TOSHIBA THB6064AH Updated Active IC
By lihaijiang in forum Manufacturer NewsReplies: 1Last Post: 09-04-2012, 03:43 AM -
Well it looks like I have to bite the bullet (solid works)
By Kai in forum SolidworksReplies: 9Last Post: 03-04-2011, 01:52 AM -
How Rotary Broaching Works
By steve3d in forum Tool & Tooling TechnologyReplies: 0Last Post: 18-01-2011, 03:17 AM -
My CNC WORKS...
By emboss.shop in forum Metalwork Project ShowcaseReplies: 0Last Post: 30-09-2009, 06:04 PM
