Page 14 of 23 FirstFirst ... 41213141516 ... LastLast
  1. #131
    I have a question about water pump. What is the size of the coupling for the hose (pvc 6mm one)? Where I can find this?
    Thank you
    Gabi
  2. #132
    Hi !
    The pipes I got with my kit were PVC 6mm. However, I do not recommend those. Personally I find PVC too rigid and prefer much more plastic hose used in gas powered remote control airplanes. If there is a store close to your house that sell that kind of planes, just get it there. It's quite cheap. Otherwise you can order it online :)
  3. #133
    I have the pipes. my question was about the connection. The brass connector.
    On mine (pump) the seller said is 18mm diameter outlet. I cant find anything with that dimension at one end and with 1/4" or 6mm on the other end.
    Quote Originally Posted by eurikain View Post
    Hi !
Name:	Water Pump-500x500.JPG
  4. #134
    Weird :/ Mine is different. It's made of plastic, exactly like the one on this kit:
    http://www.aliexpress.com/item/CNC-S...444_5,201409_1
    Though I have to admit it was quite hard to fit the pipe that came with the spindle. The coupler I have has the same size as the one on the spindle.
  5. #135
    Many of you have the same setup. Where do you find the connector?
    Gabi
  6. #136
    Quote Originally Posted by gabi68 View Post
    Gabi
    Not sure what your asking here . ? . . . The pump in the picture doesn't need or use a connector it's got a Barb so you just push the pipe on and clip it.!
    If your wanting the Barb Fitting that screws into the pump then try these people.
    http://airaccessories.fluidfittingss...s/0033000a0007
  7. #137
    Hi JazzCNC,
    The photo is for reference only. My pump came with a bigger plastic connector. I will have a look on that site.
    Still maybe know where I can buy the right one. I bought the 3/4" barb and doesn't fit, it is a hair big...
    Thx
    Gabi
  8. #138
    Got some Noob questions. Thanks for any help.
    1. Can anyone confirm if its safe to power up the VFD without the spindle connected for setting the parameters at the beginning ?
    2. I have already purchased 3 core foil shielded Belden Cable for my spindle.
    http://www.ebay.co.uk/itm/111817521022
    Is this ok ?
    I just read i was supposed to use 4 core CY Cable.
    3. Do i have to earth the spindle at the spindle end by removing the top and making a ground point and connect to pin 4?
    E.g. Should I have 4 core cable as well as the shielding ?
    Martin
  9. #139
    Quote Originally Posted by mturneruk View Post
    Is this ok ?
    Martin
    1. I believe it is ok to run the vfd without being connected BUT do not connect or disconnect with it powered up.
    2. Yes it will be OK CY cable is generally used but you have already purchased it so use it.
    3. It is ok to earth the shield at the VFD end only, 4 core is not a necessity .
  10. #140
    Just to clarify, this is true for the shield but you should ideally also earth the body of the spindle, not relying on earthing through the machine frame as the bearings are not predictable.
  1. Chinese Spindles
    By Ricardoco in forum Generic Chinese Spindles
    Last Post: 05-12-2016, 12:16 AM
  2. Info on Chinese suppliers, their reliability and reputation
    By Want2build1 in forum Marketplace Discussion
    Last Post: 07-12-2013, 09:37 PM
  3. NEW MEMBER: Seeking advice on a CNC setup for (one off) machining carbon fiber plate
    By Tomcat in forum New Member Introductions
    Last Post: 03-03-2013, 01:43 PM
  4. Chinese spindles
    By Colin Barron in forum Marketplace Discussion
    Last Post: 23-08-2011, 08:58 PM
  5. Chinese 1.5kw Spindles
    By jcb121 in forum Generic Chinese Spindles
    Last Post: 28-07-2011, 06:20 PM
