27-12-2015 #142
In my Belden wire it has 3 insulated cores, an. Outer foil shield and a non insulated wire together with the shield. So are you saying connect the shield and non insulated wire to the spindle body at one end and to ground at the vfd end?
04-01-2016 #144
04-01-2016 #146
I was talking about the part where you solder the cable to the shield. I'd be curious to see how you do it.
Ok It depends on how course the weave is on the shield. If it is course you can use a pointed object and tease the cores out through it then you have a strand of shield left to solder to.
If it is tight weave then you have to cut it and then twist it to a strand with the ground drain wire and then solder an earth wire to that . use heat shrink to make it neat. In this pic it is the blue wire with green/yellow sleeve to identify it as earth star point. but the same can be done for the spindle...Clive
04-01-2016 #148
Thanks for the image :) I see what you mean.
Now, when you open the spindle cap, you just solder a wire from pin 4 to the spindle shield ? I mean, literally to the metallic shield right under the cap ?
Ok it depends if you have 3 or 4 pins on your spindle socket if you have 4 one of them may not be connected to anything. I took the end cap off and soldered a wire to the vacant pin and put a longer screw in the socket and attached the wire to a ring connector which then fitted over the longer screw and fastened it with a nut inside. Then you can use that pin as the earth in the plug. If you only have 3 pins in the socket then you have to attach the earth to the spindle or clamp.
04-01-2016 #150
Perfect description, thanks Clive, you're an ace :)
Chinese Spindles
By Ricardoco in forum Generic Chinese SpindlesReplies: 123Last Post: 05-12-2016, 12:16 AM -
Info on Chinese suppliers, their reliability and reputation
By Want2build1 in forum Marketplace DiscussionReplies: 38Last Post: 07-12-2013, 09:37 PM -
NEW MEMBER: Seeking advice on a CNC setup for (one off) machining carbon fiber plate
By Tomcat in forum New Member IntroductionsReplies: 0Last Post: 03-03-2013, 01:43 PM -
Chinese spindles
By Colin Barron in forum Marketplace DiscussionReplies: 15Last Post: 23-08-2011, 08:58 PM -
Chinese 1.5kw Spindles
By jcb121 in forum Generic Chinese SpindlesReplies: 12Last Post: 28-07-2011, 06:20 PM
