Page 2 of 8 FirstFirst 1234 ... LastLast
  1. Ok, I've managed to uncover the motors
    Motors are a Shinano SST58D 3830. 1.5v 4.4A
    data sheet here http://shinano.com/motors/docs/SST58D.pdf
    Anyone give me any hints on what this means - good or bad news? Please tell me I don't have t replace these!!
    They look OK to me. Can you find out what the secondary Voltage says on the transformer (or can you measure the DC Volts across the blue capacitor) in the power supply as Dean (Jazzcnc) has asked before
  3. Ahh across the blue capacitor, thank you! - it measures 24.5v .... Not the 36v suggested!
    Quote Originally Posted by craynerd View Post
    Ok then it looks like you will need to build a new power supply it basically consists of the transformer, Caps and a rectifier about £45-£50. What part of Manchester are you in?
  5. #15
    Like clive says motors are fine and you will be better using a new PSU with more voltage. If tight on budget then Technicly don't need a new psu and the machine will work with 24v even with new drives but you'll get much better performance with more volts. Not changing would be like having a ferrari and never taking out of 2nd gear.!
  6. Quote Originally Posted by JAZZCNC View Post
    Jazz, now you have seen the motors, any suggestion as to the best value but quality drivers?
    Sent from my SM-G900F using Tapatalk
  7. Quote Originally Posted by Clive S View Post
    Hi Clive , North Manchester near Bury
  8. #18
    These will work nice for that small machine. http://www.ebay.co.uk/itm/Leadshine-...kAAOSwNSxVIEIl
    Run them with between 44-48Vdc using an unregulated PSU. Either build one like clive says which is very easy and done exactly like what's inside the machine already just with larger transformer and capacitors. You will probably be able to re-use the bridge rectifier may even be able to re-use the Capacitor depending on it's size and just add another.? Thou for the cost you may be better just replacing.
    WARNING### Capacitors can give you nasty shock when charged up so don't go fiddling unless your sure they are dischraged. Always check with a meter before touching across termianls.
  9. Dean, how would these compare to the cnc4you CW-5045 ?
    Sent from my iPad using Tapatalk
  10. #20
    Not used them and the spec doesn't give much away which is always a bad sign IMO. The spec sheet reads like they are just Analog Chopper drives and nothing special.
  1. Vevor 3020 cnc Autolevelling
    By iBeta in forum Machine Discussion
    Last Post: 22-11-2015, 07:08 PM
  2. DIY 3020 CNC I/O Board
    By Pointy in forum Electronic Project Building
    Last Post: 27-07-2015, 10:48 PM
  3. NCStudio to Mach3 question for a chinese 3020 router
    By Fivetide in forum Chinese Machines
    Last Post: 11-04-2015, 10:37 PM
  4. is a cnc 3020 right for the jobs i need doing
    By RsvRcarl in forum Milling Machines, Builds & Conversions
    Last Post: 28-03-2012, 01:34 AM
  5. Improving your CNC3040/3020
    By DanielF in forum Motor Drivers & Controllers
    Last Post: 22-11-2011, 01:48 PM
