Thread: Comparing motion controllers...
11-02-2016 #21
There is nothing wrong with the Ethernet Smoothstepper if you are going to buying a breakout board. The support is fine now, even though in the past it was sketchy. I know Jazz has his opinion on the generic breakout boards and he is justified. To be fair, we have seen countless conversions and builds use the standard 5 axis BOB's and work just fine. The latest incarnations of them will run on 12-24Vdc and even modulate 0-10V for combination with VFD's while being fully optoisolated. You do need to be careful with your cabling and grounding whatever controller/BOB you go for so it is all up to you which one you prefer.
Backlash compensation has been painted as a hack, however even the big boys do it (even when they use ground screws). That is the only way you can use C7 cheap ballscrews and not chase your tail wondering why your circles are not round. If you can afford the C5 with preload or zero backlash then yes you can forego backlash compensation.https://emvioeng.com
Wiring Steppers to controllers
By liamo1991 in forum Motor Drivers & ControllersReplies: 1Last Post: 05-09-2013, 01:58 AM -
PCI Motion Controllers
By IanS1 in forum Motor Drivers & ControllersReplies: 0Last Post: 16-05-2013, 12:13 AM -
Difference between controllers and Cad/Cam programming???
By 0625272 in forum Computer SoftwareReplies: 0Last Post: 23-06-2011, 08:40 PM -
Programmable logic controllers
By cncezee in forum Motor Drivers & ControllersReplies: 12Last Post: 15-11-2010, 08:44 PM -
FOR SALE: DC Motor controllers - 24v and 36v up to 160A
By HiltonSteve in forum Items For SaleReplies: 10Last Post: 02-06-2009, 10:36 PM
