Thread: Comparing motion controllers...
11-02-2016 #25
I say for router it's not required. If you have that much backlash that it shows in wood or light aluminium work then you need to address the problem. Software won't help you.!
To answer George(Komatias) mentioning the Big boys using backlash comp then it's like comparing apples with oranges. There control software is in another league to anything we use and can't be compared. They are also talking about tiny tiny amounts of backlash that you could only dream about getting close to achieveing.
The ESS is perfectly good Controller I never said it wasn't and I do use them. But it offers very little other than individual homing for a stepper system. The Extra frequency it allows you can't use. The BOB is potential problem despite what may be said and unless you buy decent quality BOB then it's like a lottery to how long it lasts or starts giving you troubles. In the past I've built machines with BOB's which work fine for years then all of sudden for no apparent reasons hair pulling issues start creaping into the machine. 99% of the time BOB is the cause.!
Regards using Timing belts then you won't loose any precision and keeps perfect sync of screws. If the machine isn't too large then I'd use Belts over Twin motors every time.
Wiring Steppers to controllers
By liamo1991 in forum Motor Drivers & ControllersReplies: 1Last Post: 05-09-2013, 01:58 AM -
PCI Motion Controllers
By IanS1 in forum Motor Drivers & ControllersReplies: 0Last Post: 16-05-2013, 12:13 AM -
Difference between controllers and Cad/Cam programming???
By 0625272 in forum Computer SoftwareReplies: 0Last Post: 23-06-2011, 08:40 PM -
Programmable logic controllers
By cncezee in forum Motor Drivers & ControllersReplies: 12Last Post: 15-11-2010, 08:44 PM -
FOR SALE: DC Motor controllers - 24v and 36v up to 160A
By HiltonSteve in forum Items For SaleReplies: 10Last Post: 02-06-2009, 10:36 PM
