Thread: need help setting motor pins
hi Nick, thanks for your reply. I don't have any paperwork. the system did work ok until I started to press too many buttons.
here are pics of the board with the x,y,z axis marked . also some pics of the mach 3 program showing pins set up at the moment. at the time of the pictures the control was off.
19-02-2016 #2
That really pretty much eliminates Mach3 config problems and wiring faults, still worth checking supply voltage static and under load plus all your connections, for good measure have a really close look at both sides of the board for blown tracks or signs of the escape of any "Magic Smoke".
Regards,
NickLast edited by magicniner; 19-02-2016 at 08:13 PM.
Mach 3 ports and pins problems,
By chris w in forum Artsoft Mach (3 & 4)Replies: 24Last Post: 06-04-2017, 03:25 PM -
RFQ: 16mm long stainless pins with m5 tap
By dazza in forum Projects, Jobs & RequestsReplies: 12Last Post: 11-03-2013, 03:12 PM -
Setting up stepper motor drivers
By croy in forum Motor Drivers & ControllersReplies: 25Last Post: 30-09-2012, 09:51 PM -
ports and pins for system4
By Dan Brown in forum Motor Drivers & ControllersReplies: 2Last Post: 18-01-2010, 06:37 PM -
Ports and pins help ? mach 3
By xchipx in forum Artsoft Mach (3 & 4)Replies: 0Last Post: 19-04-2009, 12:45 PM
