    Steel box section and plate had arrived earlier on in the week:
    Attachment 17758Attachment 17757
    Ended up buying a tungsten carbide blade for £80 to cut this as 5 of the 6 local suppliers I visited advised that the machine had a "non-standard" 25.4mm shaft.
    Seemed to work fine the first day but when trying to cut the box section the next day, it seemed to require a lot more time/force, I think I may be cutting too fast and wearing out the blade.
    Attachment 17759
    Ended up with a bit extra 100x50 section and too little 50x50 section, I underestimated how much box section it would require and assumed I had more than enough at 7.5m of each. Guess its true what they say about assuming!! Requested price for 1m more of each and changed the design slightly to use the larger box section for the horizontal bracing:
    Attachment 17760
    Other than the two sections I am ordering, all box section has been cut, but unsure if some of it is still good as I think maybe 3 sections (bed supports and gantry box section) are 3-5mm shorter than what I needed, will this be OK filling up with weld?
    Attachment 17761
    Was hoping to have it all welded up this week but ended up being a slow start with the few hick ups pushing things back a week
    All in all, it was a good experience and even though I had some problems, I enjoyed it and learnt a lot of new things
    Some questions I hope you guys could help me with please:
    • From what I understand 5754 aluminium is the grade but if specified as tooling plate, would this be OK for use on the Z-Axis without having to face it off?
    • As this machine will be moved 3 times (welded in workshop, epoxy leveled in a smaller room for heating and installed in a shed) is it worth welding some adjustable feet to the legs?
    Hi
    I don't think you will be able to bridge 5mm with weld, if you had say five joints you could maybe bridge 1mm on each, better to make the frame fit what you have now, or maybe weld in a 5mm spacer plate somewhere. Done properly this could work.
    Yes machined aluminium tooling plate is very good and ideal to use as-is.
    Yes, fit heavy adjustable feet, always useful, but not the weedy ones with M8 threads ;)
    Quote Originally Posted by examorph View Post
    You'll be putting a tremendous amount of heat into the steel if you try to fill it. Why don't you do as Dave says and put a spacer, or cut a bit more off and weld a plate onto each end?
    • Yes tooling plate is the thing to go for, needs no surfacing.
  4. Definately, M12 are the ones to go for.
    I was looking at your design just now and can see a potential problem for you mounting your ballscrew nuts on the longest axis (X or Y depending on what you call it!!). You've got them bolted from the back, how are you going to tighten them after adjusting them when fitting the ballscrews? You might also want to do the same for the gantry one as although you might be able to get to it from the top there will be a pulley in the way. I did exactly the same thing and had to change my ball nut housings so you can bolt from the outside, just a thought
Neil...
Build log...here
Reply With Quote Reply With Quote
  • #4
    Thanks guys, will get some adjustable feet sorted (>=M12) and also cut out some 50x50x10mm steel plate to weld to the frame legs for this. Will also make adjustments where I can to reduce the 5mm gap on the steel box section.
    njhussey - Thanks for spotting that. The clearance behind the plate is 10mm, think I could get away with using hex heads and tightening them up with a spanner?
    Attachment 17769Attachment 17768
  • #5
    Been a nightmare finding a local supplier that does box section without a 7.5mtr minimum order charge, but got one eventually who can do me some off cuts at a 3mm wall for a good deal.
    Will the 3mm wall thickness box section be OK for the bed support beams and horizontal supports shown below in green? Will it also be OK to weld?
    Attachment 17786
  • #6
    Lives in Marple Stockport, United Kingdom. Last Activity: 11 Hours Ago Forum Superstar, has done so much to help others, they deserve a medal. Has a total post count of 3,342. Received thanks 618 times, giving thanks to others 82 times. Made a monetary donation to the upkeep of the community. Is a beta tester for Machinists Network features.
    Attachment 17786
    The main problem apart from resonance with 3mm box is that it is not quite thick enough to tap 4mm or 5mm would be a better option. If it is just for the green bits then it is probably OK
  • #7
    3mm is ok, if size is 80x80 or 100x100. I wouldn't use it for smaller than that.
    No problem with tapping and screwing 3mm, just have to be careful and drill holes using a guide so they are true 90degree square to profile.
  • #8
    6mm bolt in 3mm I beg to differ its right on the edge and suppose he wants to tap 8mm
  • Thread Information
    1. BUILD LOG: First Build 5 x 12 Steel Frame CNC router
      By Scott Damman in forum DIY Router Build Logs
      Last Post: 18-01-2017, 06:36 PM
    2. BUILD LOG: New Build, Aluminium Frame Router/Mill
      By Davek0974 in forum DIY Router Build Logs
      Last Post: 31-08-2016, 05:28 PM
    3. BUILD LOG: Steel frame cnc router design/build
    4. BUILD LOG: First steel diy CNC router build
    5. BUILD LOG: 7' X 4' Steel frame build
