20-04-2016 #2
The coupling can slip down onto the ballscrew and off of the motor shaft without the screw or the axis actually moving poor grip and gravity with a little help from vibration, also the video of the screw is someone elses problem not stated by this poster as far as I can tell.
If a betting man I would look at first item discounted as the problem, thin double sided pads probably applied towards edges with a little give amplified at centre as a helix screw into piece pulling it up or pulling the bit down with forces generated to clear the chips, the solutions are being given without identifying the problems which is illogical.Last edited by lucan07; 20-04-2016 at 09:42 AM.
The Following User Says Thank You to lucan07 For This Useful Post:
Cutting deeper in areas???
By alboy in forum Gantry/Router Machines & BuildingReplies: 20Last Post: 29-01-2015, 05:54 PM -
Small 3D Engraving
By magicniner in forum General DiscussionReplies: 2Last Post: 01-01-2015, 10:46 AM -
Font cutting
By petesos in forum Machine DiscussionReplies: 9Last Post: 17-05-2014, 08:14 PM -
RFQ: Wood Sign/engraving required, small job one off money waiting...
By njhussey in forum Projects, Jobs & RequestsReplies: 8Last Post: 21-09-2013, 07:12 PM -
Hi font help please
By cockneyrebel in forum Computer SoftwareReplies: 3Last Post: 12-04-2013, 06:39 PM
