Thread: Denford Microrouter V4
If you run machloader create a copy of your setup its a good idea to have a standard screen setup to troubleshoot, and you could run autotune.
Are you sure not mixing Motor tuning and mach default mm's and inches 26x25.4 = 660 would only be 20% out closer than 400%.Last edited by lucan07; 03-06-2016 at 06:00 PM.
03-06-2016 #2
03-06-2016 #3
You are using a smoothstepper so that I suspect generates pulses rather than PC, I would look closely at the smoothstepper settings if there is a multiplier or something there, some do for servo's to get up to speed. Some good videos on warp9 for setup I saw when considering the smoothstep
03-06-2016 #4
ok set the drivers to 32 steps and half current
used the auto tune feature and doing a full x travel I get 550mm, soft limt isn't working for some reason so I need to look into that
03-06-2016 #5
I got a soft limit bug in latest version went back to previous one ending .20 after hearing a fair few bugs in latest version.
03-06-2016 #6
restarted mach and they are now working.
the machine is working, still need a smooth a few things out but its working
The Following User Says Thank You to andy_con For This Useful Post:
03-06-2016 #7
Its coming together that first cuts always the best
FOR SALE: Denford Starmill ATC
By andy_con in forum Items For SaleReplies: 1Last Post: 14-02-2016, 10:16 PM -
1999 Denford Microrouter problems
By D-man in forum Denford RoutersReplies: 5Last Post: 21-03-2015, 12:43 PM -
Denford MicroRouter Compact, what to do next?
By paul_m in forum Denford RoutersReplies: 2Last Post: 08-01-2015, 09:51 AM -
FOR SALE: Denford cnc
By john legge in forum Items For SaleReplies: 4Last Post: 17-03-2013, 11:18 PM -
Denford CNC MicroRouter
By mekanik in forum Milling Machines, Builds & ConversionsReplies: 12Last Post: 27-08-2012, 06:57 PM
