Thread: Denford Microrouter V4
Andy,
That all looks great, but have you considered adding a V-carve type path about 4mm deep with a V-bit cutter for the outlines?
That would give you near pin-sharp corner definition on characters and graphics where they merge and the cutter diameter cannot manage sharp corners,
Regards,
NickLast edited by magicniner; 10-06-2016 at 12:53 PM.
10-06-2016 #2
the machine only came with a single 6mm collet so im limited to 6mm shank tools at the moment. ive ordered some more collets from the us which im waiting to arrive, once I get them I can start using more tools.
that engraving one done with a v-bit router tool, but only 0.3mm deep. were I to have the right collet I would have done it 1mm deep with a 1mm end mill
im pretty new to wood, so still learning what gives the best results. ive since painted that engraving so its looks much better now
10-06-2016 #3
The Following User Says Thank You to magicniner For This Useful Post:
10-06-2016 #4
no idea how to do that
10-06-2016 #5
You have to use a CAM package that supports V-Carve paths, it's the only way to get sharp corners on deep cuts, otherwise you're limited by your tool diameter, it uses the fact that a V-bit cutters diameter varies with depth to give you corners as sharp as the tip cutting diameter of a tapered tool tip.
10-06-2016 #6
10-06-2016 #7
FOR SALE: Denford Starmill ATC
By andy_con in forum Items For SaleReplies: 1Last Post: 14-02-2016, 10:16 PM -
1999 Denford Microrouter problems
By D-man in forum Denford RoutersReplies: 5Last Post: 21-03-2015, 12:43 PM -
Denford MicroRouter Compact, what to do next?
By paul_m in forum Denford RoutersReplies: 2Last Post: 08-01-2015, 09:51 AM -
FOR SALE: Denford cnc
By john legge in forum Items For SaleReplies: 4Last Post: 17-03-2013, 11:18 PM -
Denford CNC MicroRouter
By mekanik in forum Milling Machines, Builds & ConversionsReplies: 12Last Post: 27-08-2012, 06:57 PM
