    the machine only came with a single 6mm collet so im limited to 6mm shank tools at the moment. ive ordered some more collets from the us which im waiting to arrive, once I get them I can start using more tools.
    that engraving one done with a v-bit router tool, but only 0.3mm deep. were I to have the right collet I would have done it 1mm deep with a 1mm end mill
    im pretty new to wood, so still learning what gives the best results. ive since painted that engraving so its looks much better now
    Andy,
    That all looks great, but have you considered adding a V-carve type path about 4mm deep with a V-bit cutter for the outlines?
    That would give you near pin-sharp corner definition on characters and graphics where they merge and the cutter diameter cannot manage sharp corners,
    Regards,
    Nick
    Quote Originally Posted by andy_con View Post
    V-Carve paths are 3D and lift the V Bit at the corners to give straight lines/accurate curves right up to any sharp corners,
    Regards,
    Nick
  3. The Following User Says Thank You to magicniner For This Useful Post:
    no idea how to do that
  5. #4
    You have to use a CAM package that supports V-Carve paths, it's the only way to get sharp corners on deep cuts, otherwise you're limited by your tool diameter, it uses the fact that a V-bit cutters diameter varies with depth to give you corners as sharp as the tip cutting diameter of a tapered tool tip.
  6. #5
    I use cambam
  7. #6
    I use cambam
    It doesn't look like CamBam does V-Carve style tool paths :-(
  8. #7
    no word of a lie my 40 trial uses of cambam ended today and I was going to purchase it. maybe there is a better option out there I could spend my money on?
  1. FOR SALE: Denford Starmill ATC
    By andy_con in forum Items For Sale
    Last Post: 14-02-2016, 10:16 PM
  2. 1999 Denford Microrouter problems
    By D-man in forum Denford Routers
    Last Post: 21-03-2015, 12:43 PM
  3. Denford MicroRouter Compact, what to do next?
    By paul_m in forum Denford Routers
    Last Post: 08-01-2015, 09:51 AM
  4. FOR SALE: Denford cnc
    By john legge in forum Items For Sale
    Last Post: 17-03-2013, 11:18 PM
  5. Denford CNC MicroRouter
    By mekanik in forum Milling Machines, Builds & Conversions
    Last Post: 27-08-2012, 06:57 PM
