27-07-2016 #11
This will answer both of you.
My orginal vertical machine I used to park at the bottom which was the best place to park for me but could park anywhere I liked as it didn't fall down due to light gantry. Since then I've aquired different machine with gantry using the same design has neil's which is much heavier and like neil slowly creeps down when power off.
So the solution was counter balance and now can park where ever I like. It also takes lot of the strain off the motors while working meaning I can tune motors a little more aggresive if I like.
Don't ask me to show the counter balance because it's rougher than rough(Which sure Clive will confirm) and like every thing I do just for my self it's thrown together to get it working ASAP. To give an idea consists of bit of old timing belt and tractor weight.
BUILD LOG: A3 Router Build
