14-09-2016 #12
Good Evening Guys
Thank you very much for the replies. I didn't know about the other type of couplers and so Thank you. Although Because I will go with the Pulleys then it will be changeable on the speeds and torque (Although thats another learning curve for the maths )
Thanks dean Yes your right Its the problem when I get started I buy and then it sits there waiting for me for ages and I would have been better to learn and then buy after so thank you very much for slowing me down. Although where were you when I brought my AC cobra replica
. still not bad that's only sat there for 7 years i'm sure they get better with age well that's if it worked.
I will got through the Logs and start to learn and do it properly I didn't really know where to start so the thread is great with the suggestions on the items that are best to look towards.
I have just come in from the Garage and still working on the frame although that is looking a bit more than box section now but only just.
I didn't have your details previously dean but if you don't mind me speaking to you at some stage when you have a minute it would be gratefully received.
Thank you all as usual for all the help you give
Rob
FOR SALE: SBR 20 supported round rails and bearing blocks
By JoeHarris in forum Items For SaleReplies: 10Last Post: 09-02-2015, 02:06 PM -
WANTED: 2 x 20mm Fully Supported Round Rail
By longy in forum Items WantedReplies: 0Last Post: 30-03-2014, 09:21 PM -
round, supported or profiled rail?
By mocha in forum Rails, Guideways & BearingsReplies: 0Last Post: 26-07-2012, 03:44 PM -
WANTED: 2 x 20/16mm supported round rail
By D-man in forum Items WantedReplies: 4Last Post: 30-10-2011, 11:08 PM -
Profile v Supported Round Rail
By Rogue in forum Rails, Guideways & BearingsReplies: 5Last Post: 15-09-2011, 09:29 PM
