Thread: Emco PC120 Turn
Page 7 of 15 FirstFirst ... 56789 ... LastLast
  1. #61
    OK, found it.
    https://www.google.co.uk/url?sa=t&rc...32479545,d.bGs
    It's basically the same one in the link. Yay, at least now I can see some wiring options.
    The easy way is to use one of these relay modules triggered by a spare output A or B (Pulse or Direction). You can get the relays in singles or multiples at least up to 8 on one board.
  2. The Following User Says Thank You to cropwell For This Useful Post:
  3. #62
    Chaz's Avatar
    Oh, thanks. Didnt know this was possible. Do you have a link or similar to one of these please?
  4. #63
    They are all over eBay, just search for 'relay module 5v' and limit to UK if you want it fast.
    Here's one example of a supplier - http://www.ebay.co.uk/itm/1-2-4-8-16...f5lyx157fF9xGQ
    Cheers,
    Rob
  5. #64
    Chaz's Avatar
    Awesome thanks
  6. #65
    Chaz's Avatar
    That should work well. Does it take much messing about with Mach3 to get this to work?
  7. #66
ID:	19676Click image for larger version.
ID:	19677 I use P16 for coolant (just an air blower really) and P17 to turn the spindle on (Kress, not a three phase one with speed control)
    You may like to play with active high / low and whether you connect to NO or NC on the relay as there can be some activity on the pins before Mach3 takes control.
    Cheers,
    Rob
  8. #67
    Lives in East Lothian, United Kingdom. Last Activity: 4 Days Ago Forum Superstar, has done so much to help others, they deserve a medal. Has a total post count of 2,994. Received thanks 376 times, giving thanks to others 9 times.
    Thanks. Appreciated. Ive emailed APT support, ive used them in the past and they are really good but finding a parting solution for this otherwise excellent little CNC lathe.
    Realised earlier that I've actually got a GTN style in the lathe just now.
    It's this one - https://www.shop-apt.co.uk/part-off-...2mm-shank.html
    Tip to the back of the head is about 26mm. I only remembered after I'd turned the lathe off, and the parting tool was at a less than ideal angle to accurately measure.
    I also measured a 26mm diameter WDN holder, and the tip to back of head is 21.1mm
  9. #68
    Chaz's Avatar
    Thanks. Hadnt seen your reply but APT believe it should fit so ive ordered one of these.
  10. #69
    Chaz's Avatar
    Cheers,
    Rob
  11. #70
    Chaz's Avatar
    So I ordered this one - https://www.shop-apt.co.uk/part-off-...2mm-shank.html. Its like 2mm too long but I can grind away some of the lip that's in the way. Kudos to APT for the quick delivery as usual.
  1. Mach Turn
    By Kai in forum CAD & CAM Software
    Last Post: 02-08-2016, 02:40 PM
  2. Denford Star Turn 3
    By MarkBrown in forum Workshop & Equipment
    Last Post: 02-12-2014, 10:57 PM
  3. Getting the stepper to turn
    By thorphar in forum General Electronics
    Last Post: 16-09-2014, 07:48 PM
  4. 11 hours of trying to get the motors to turn, help please
    By Wotsit in forum Stepper & Servo Motors
    Last Post: 05-02-2013, 03:07 AM
  5. LED not turn on
    By Awel in forum Motor Drivers & Controllers
    Last Post: 06-12-2011, 06:59 AM
