  1. #2
    Hi
    In general this is easy to build design but I would change it slightly:
    1. Put rails on spindle plate and blocks on Z plate (this will give zero torque at top spindle position, your design create torque on spindle plate regardless of the spindle position)
Name:	Assem ballscrew10.JPG
    2. Y blocks I would install on top rather on the bottom (it easy to make guard if you want to protect blocks against dust) - too big arm from bottom blocks to top of the gantry - think about forces
Name:	Gantry forces.jpg
    3. Direct drive is transfer vibration to the motor better to use gear and belt.
    4. I would use one motor for Y drive driven by pulley
Name:	X-drive complete.JPG
    5. Gantry should be connected on the bottom - not open. This make it stiffer and side plate a bit thin
Name:	Gantry ballscrew3.JPG
  2. The Following User Says Thank You to Tom J For This Useful Post:
  1. BUILD LOG: Comments sought on new build: A CNC Router for RC Gliders and Planes
    By njhussey in forum DIY Router Build Logs
    Last Post: 13-04-2020, 05:03 PM
  2. BUILD LOG: First Build-Steel Gantry CNC - Comments on design wanted
    By olaff in forum DIY Router Build Logs
    Last Post: 06-12-2015, 08:34 PM
  3. New build – input/comments appreciated
    By ngundtoft in forum Gantry/Router Machines & Building
    Last Post: 05-10-2015, 11:38 AM
  4. My new, and first build....comments greatfully received
  5. noob first build
    By japcarmaniac in forum Gantry/Router Machines & Building
    Last Post: 13-03-2012, 11:56 AM
