    Thanks for that. I'm a little concerned that a belt that long will introduce other issues, so will see what to do about that. Will attempt to alter the z axis for a belt drive. I don't suppose it should be too difficult.
    Quote Originally Posted by Tom J View Post
    belt transmission gives you extra flexibility, you can adjust gear ratio means=feed, easier do deal with resonance if any occurs, allows to mount motor in two position (up side down and shaft up).
    Z axis takes most vibration as is driving spindle up and down, so those shaky shaky gets to the motor and disturb in high speed. My first machine was driven by coupling - cheap Chinese, than with plastic insert, odiham finally end up with 1:1 pulley.
    Y drive, if your power supply can handle biggest nema 23 3Nm motor without extra voltage than one motor should be ok and will wait only few hundreds grams more than 1.9Nm. Advantage of having one motor and two ballscrew is lack of need for squaring the gantry (one motor less, 2 sensor less)
    Motor have to be powerful enough so they do not loos steps, if you loose steps you loose your job, material, time.
    Gantry - more braces make it stiffer - joining them under bed will increase the weight but benefit you gaining by stiffer, more accurate machine are far more important.
    I hope somebody else will give you some inside, I only build 3 machines and even on last one I would make something different, now I designed another one will post it soon.
    Good luck with the build
    Quote Originally Posted by danilius View Post
    use good quality gates HDT 15mm braided one - there will be flex which shouldn't give you error bigger than 0.02mm (I referring here to my steel machine which was 115kg)
    Food for thought. Thanks! Time to get back to drawing :-)
    Connecting the gantry at the bottom will give little benefits but, by moving the legs far apart, the base will be a lot weaker.
    Why would you put the X rails "hanging"? Only for dust/swarf protection? The side plates extension for guide blocks will deflect a lot and put pressure on the rails/blocks trying to twist them. I don't think it's worth it.
    The gantry side plates are beefy but only when looking from one direction. If you cut out one third longitudinally and bolt it perpendicular you will have more rigidity in the Y direction without any loss or weight gain. And you can connect to your t-slot profile overhang.
    OK, I think I have understood all this correctly. So, I'll move the rails up top, and stiffen up the gantry walls.
    So, I have made some changes. I wasn't convinced that the extrusion on the gantry was going to be rigid, so that has been dropped in favour of some solid lumps of metal. It is also much shorter, and the rails have been moved up to the top.
Name:	gantry perspective.png
    What I'm wondering is if there is an optimum distance between carriages for the gantry.
Name:	how close can they go.png
    I dont have any worksop equipment beyond the basic tools, so don't want to drill into the extrusions or anything, but I'm getting a bit lathered about the hseer size of the machine, given that it's only going to have a work area of 600 x 900. Currently the overall dimensions are roughly 1400mm x 940mm. I can trim a small amount off the length, but is there any way of getting this more compact?
Name:	full assembly 1.png
Name:	full assembly 2.png
    Whydon't you put the horizontal plate of the X axis carriages under the gantry side plates. You will have a lot of unnecessary weight removed and by putting the ball nut support under the same plate you can shorten the ballscrew and the main frame (to the length of the rails). The gantry will slide above the ballscrew end blocks. It is also a good point to put the ballscrews closer to the working surface/plane.
    I think you need a plate at the back of the gantry to crate a box. Even a thinner plate will increase rigidity.
    I don't think there is an optimum distance... The 20cm that you have in your project looks good to me. But I'm not an expert.
  1. BUILD LOG: Comments sought on new build: A CNC Router for RC Gliders and Planes
    By njhussey in forum DIY Router Build Logs
    Last Post: 13-04-2020, 05:03 PM
  2. BUILD LOG: First Build-Steel Gantry CNC - Comments on design wanted
    By olaff in forum DIY Router Build Logs
    Last Post: 06-12-2015, 08:34 PM
  3. New build – input/comments appreciated
    By ngundtoft in forum Gantry/Router Machines & Building
    Last Post: 05-10-2015, 11:38 AM
  4. My new, and first build....comments greatfully received
  5. noob first build
    By japcarmaniac in forum Gantry/Router Machines & Building
    Last Post: 13-03-2012, 11:56 AM
