Thread: Newbie needs CNC advice
07-02-2017 #2
Hi Paulus yes i am, im running rightmark cpu clock utility without that the pulse frequency wont stay stable on 25000 instead it will jump around 2300 to 23900
Its everything to do with the cpu not the output voltage from the parallel port
link is here http://www.majorgeeks.com/files/deta...k_utility.html
if you have a laptop with parallel port that wont run mach 3 at 25000 then run this piece of software and under management setting check box "Run HLT command when os is idle"
it works for me and i would be interested if it works on other laptopsLast edited by Steel; 07-02-2017 at 08:16 PM.
07-02-2017 #3
I have the very same laptop, IBM T42 and am using it with my CNC router. I had and still have troubles with its parallel port. This is why I do not want anyone to go through what I went...
I'll explain the details later when I'll have the time. And I'll check the software that you're pointing, even if I'm a bit skeptic
BUILD LOG: Hi newbie looking for advice
By bluebug in forum DIY Router Build LogsReplies: 13Last Post: 30-08-2016, 11:41 PM -
Newbie hoping for acrylic advice
By Red_Stafford in forum New Member IntroductionsReplies: 12Last Post: 25-06-2016, 07:11 PM -
RFQ: Advice for a newbie, please - holes and spheres - 5 axis drilling
By alixus in forum Projects, Jobs & RequestsReplies: 0Last Post: 06-05-2015, 02:39 PM -
Which controller and motors? Newbie advice please
By Nealieboyee in forum Motor Drivers & ControllersReplies: 14Last Post: 16-10-2012, 02:56 PM -
newbie need advice on cnc machine to purchase? routoutcnc machines any good?
By wyndham in forum Milling Machines, Builds & ConversionsReplies: 9Last Post: 27-05-2011, 08:54 PM
