  1. The black wire appears to be linking the CM and FWD terminals, as well as providing a common feed (probably to provide the common for switching the inputs).
    You'll have to go through the settings menu (F3.0 - Pg32 in the manual) to see what X1, 2, & 3 have been configured to do.
    The TA/TC is an output, again you'd have to check the settings to see what it's set to (F3.8 - Pg 32 again).
    I'm not sure what Eding outputs, but you may want to reconfigure the drive so it uses an analogue 0-10V input to set the speed.
    Spindle is 3Kw.
    Spindle is 3Kw.
    Im sure it had 4.5 written on it. I may be wrong. But managed to get it all up and running now it's just the spindle I need sorting happy Sunday
    https://youtu.be/nHRegkThV8w
    OK Guys, everything is as per the manufacturers settings (in parameters pages) APART FROM the following:
    AUXILIARY RUNNING PARAMETER UNIT
    F4.8 - 0.50
    MULTI SPEED FREQUENCY
    F5.1 - 100
    F5.3 - 200
    F5.4 - 250
    F5.5 - 300
    F5.6 - 350
    F5.7 - 400
    First one that gets her fired up, will get a drink :)
    could really do with her up and running for tomorrow, so any help will be much appreciated, even if i can get it running in manual mode i just cant figure it out
  6. So it looks like it's just been wired to provide 3 different speeds, depending on what input is activated.
    What kind of output does Eding provide?
    For a quick get you going option, I'd think that provided you just connected one of the three speed input wires (red/green/yellow) to the common (black), then you'll get the spindle running.
    Eding CNC provides 0-10v and a tool option.
    http://www.edingcnc.com/upload/files...flyer_tech.pdf
    screenshot of the VFD section http://prntscr.com/eltm6t
    Pins screenshot http://prntscr.com/eltme8
    OK Before i report with the Parameter settings i do know (thanks to google translate on the phone, AWESOME!), that the following wires were plugged into the old board for:
    RED: spindle Low
    GREEN: Spindle in
    YELLOW: Spindle High
    BLACK: was into 5v
  1. FOR SALE: Eding cnc controller
    Last Post: 01-08-2016, 03:31 PM
  2. Eding cnc
    By Ben-bee in forum CAD & CAM Software
    Last Post: 17-05-2016, 08:48 PM
  3. Setting ADTECH servos with Eding CNC software steps/AppUnit
    By D-man in forum Stepper & Servo Motors
    Last Post: 24-04-2016, 02:50 PM
  4. CONVERSION: Sieg X2 super with ball screws and Eding CNC controle
    By Soren DK in forum Conversion Build Logs
    Last Post: 11-04-2016, 08:40 PM
  5. Eding CPU5A4E controller and Siemens G110 VFD.
    By calgone in forum EdingCNC (CPU5, CPU5A)
    Last Post: 06-02-2015, 11:31 PM
