    looks like it should be fine.
    Just beware that your bed won't be level, so bolting the clamp directly to the bed won't give you a level surface either.
    Ideally you need to bolt on a spoil board of some description and use the machine to skim it down. That will give you a flat surface to screw the clamp down into.
    Yea I heard about that being a problem and looks like it is a bit off.
    Wood enough for a spoil board when working with aluminium?
    MDF or similar would be ok as long as you aren't using much coolant. If you have any moisture resistant lying around that is a bit more stable in terms of dimensions and changes in humidity etc but far from essential.
    You could also just bolt down a small piece where you intend to put your vice, rather than the whole bed. You would just have to re-skim it if you remove it but that's not a big deal for a small piece like that.
  4. The Following User Says Thank You to Zeeflyboy For This Useful Post:
  5. #4
    That's a good idea. I was planning on keeping the vice at the far left side and leaving the rest available to other projects that I need to do.
  6. #5
    So this is the case that I am milling out of EcoCast.
    These are the end mills I have so far.
    3.175mm http://www.ebay.co.uk/itm/1824106825...%3AMEBIDX%3AIT
    2mm https://www.aliexpress.com/item/10pc...608.0.0.EJZ3Jx
    1mm https://www.aliexpress.com/item/10pc...608.0.0.EJZ3Jx
    The case is like 75x60mm so I don't want to carve that all out with a 3.175.
    Was thinking of getting something along the lines of a 6mm end mill to do the main hogging out.
    What is the max these spindles can take?
    I have collets up to 12mm.
    Also, where is the best place to learn speeds and feeds? I have been testing these 3mm on a bit of this EcoCast and broke 2 end mills within minutes.
    One I accidentally knocked into the work piece. The other because I did not know how to correctly set up the Z in Fusion CAM.
  7. #6
    Lives in Marple Stockport, United Kingdom. Last Activity: 15 Hours Ago Forum Superstar, has done so much to help others, they deserve a medal. Has a total post count of 3,348. Received thanks 620 times, giving thanks to others 90 times. Made a monetary donation to the upkeep of the community. Is a beta tester for Machinists Network features.
    Have you thought about using foam etc. to practise on that way it will be more forgiving when you dive into it.
  8. #7
    No fun without danger of snapping a bit though :p
    The wood carving was fine. Just need to learn about the speeds and feeds for when in Fusion.
  1. New 6040 owner looking for advice from others with a chinese 6040/3040
    By itsmillertime in forum Machine Discussion
    Last Post: 14-10-2019, 08:30 AM
  2. Newbie question re converting my 6040 machine to use a laser
    By GaryWilliams in forum Laser Machines & Building
    Last Post: 19-10-2015, 03:09 PM
  3. 10 / 15mm thick 6061 aluminium alloy sheet ?
    By rnr107 in forum Marketplace Discussion
    Last Post: 14-01-2014, 12:15 AM
  4. FOR SALE: Polypropylene compound
    By Bjh1985 in forum Items For Sale
    Last Post: 08-09-2013, 09:39 AM
  5. NEW MEMBER: Newbie From China
    By jenniferxu in forum New Member Introductions
    Last Post: 04-01-2011, 06:02 PM
