    I have a possible new project - welding fixture for HF-welder.
    Overall the fixture is quite basic except for the brass electrode.
    Electrode profile dimensions 30x6,5mm. Overall fixture size is 900x700mm
    I have not seen this fixture in real life, but common sense would be to bend it from a bar stock. But considering it has to have quite tight tolerances and 2 identical top and bottom contour - this makes it extremely difficult. Though I do not have any experience with brass bending...
    Surely it is not milled out from solid?! :D
    What do you think guys? How it`s made?
    mekanik's Avatar
    Lives in Barrow in Furness, United Kingdom. Last Activity: 12 Hours Ago Has a total post count of 802. Received thanks 101 times, giving thanks to others 176 times.
    Looks like annealed brass flat bar, you should be able to bend it OK.
    Mike
  3. The Following User Says Thank You to mekanik For This Useful Post:
    Could you mill a shallow slot in the back plate for the brass to sit in ? that way it would maintain accuracy.
  5. #4
    Good idea!
    I was thinking of milling out the template and bend the brass bar around that template. Guess I will have to just test it.
    Sent from my LG-H850 using Tapatalk
  1. Getting a TIG welder and need some advice please
    By cropwell in forum Welding, Brazing & Equipment
    Last Post: 09-07-2016, 06:52 PM
  2. TIG or MIG welder
    By IanS1 in forum Welding, Brazing & Equipment
    Last Post: 25-11-2013, 02:18 AM
  3. WANTED: has any one got a MIG welder for sale
    By ciscoeuk in forum Items Wanted
    Last Post: 11-06-2013, 12:14 AM
  4. Arc welder purchase.
    By alex wight in forum Welding, Brazing & Equipment
    Last Post: 02-01-2013, 08:01 PM
  5. Mig or ARC Welder... What should i go for?
    By AdCNC in forum Welding, Brazing & Equipment
    Last Post: 08-12-2011, 02:01 PM
