Page 8 of 14 FirstFirst ... 678910 ... LastLast
  1. #71
    Lives in Plymouth, United Kingdom. Last Activity: 8 Hours Ago Has a total post count of 1,747. Received thanks 298 times, giving thanks to others 11 times.
    They're a little bit bigger than the usual choc-block style connector strip, but I've used a few of these which seem to work well. They also have the advantage that because they're spring-loaded, they are much less sensitive to vibration than screw terminals. Also, each wire goes into its own little socket so no need to twist wires together as you do with choc block - always end up chasing odd strands, trying to balance the lengths of wires, etc, when I use them. Don't know if anyone sells them in smaller quantities.
  2. #72
    Thanks for the replies guys, think i've got my head wrapped around it now, would it be bad practise to splice & solder the wires then heatshrink it all up afterwards?
    Alex
  3. #73
    Quote Originally Posted by AlexDoran View Post
    Alex
    That's the way I always do it. Use screened 4 core and ground the screen to the star point in the control box.
  4. #74
    I thought I was the only one using those connectors...
    Another advantage of them is the wide range of wire diameters they can handle. In my opinion, they are much better than screw terminal blocks. Basically, the only thing I find to their disadvantage is that they don't have any good way of fixing them, so if you are in need of using a few in a small space then the looks are not as nice as using screw terminal blocks. My PSU looks a bit messy because of this, but never the less, I find them very nice to use and practical.
  5. #75
    Thanks Clive, this is what i will also be doing then.
    Done some more on the electronics whilst i wait for some bolts to come, also need to machine some mock up parts tomorrow to finish the dry assembling, then hopefully should get some movement early next week. Was confused as hell earlier trying to figure out wiring the VFD using single phase, actually it was simplest thing ever!
    Need to decide if i want to mount the controller on top of the PC Case using some kind of Arm / Swivel attachment, then fix the PC Case to the Bench the machine will be sat on, or have the Controller as a portable unit. Not sure the machine is big enough to warrant a portable one.
    Alex
  6. #76
    Alex I would be putting some insulation over the mains terminals in the box before it bites you.
  7. #77
    Yeah i got a load of Heatshrinking to do, just wanted to make sure everything was functional before i made it pretty & safe :D
    Alex
  8. The Following User Says Thank You to AlexDoran For This Useful Post:
  9. #78
    I love how you've done it all very neat, mine is going to like Beirut on a bad day lol.
  10. #79
    Not true that!
  11. #80
    Anyone know where is a good place to get some Shielded 18Awg 4 Core Cable for my steppers?? Also I've seen a few recommendations on the net but wondered what people on here were using for the Spindle cabling??
    Thanks again guys
    Alex
  1. The 2.2Kw Chinese Spindles - Info, Setup and Advice + More
    By Husky in forum Generic Chinese Spindles
    Last Post: 22-01-2021, 06:54 PM
  2. NEW MEMBER: new member building a cnc router
  3. Building a plasma table, need advice.
    By superclarkey in forum Plasma Table Machines
    Last Post: 20-09-2016, 04:57 PM
  4. NEW MEMBER: Newbie seeking CNC info for guitar building
    By rusty999 in forum New Member Introductions
    Last Post: 15-01-2016, 02:26 PM
  5. Building a hybrid CNC mill. Need advice and recommendations
