Page 30 of 63 FirstFirst ... 20282930313240 ... LastLast
  1. #291
    What are they? I first thought they were radiators I have 2 of them, when I stripped them off they were full of water. Came from a large controller box for automated machinery, also recovered a 75amp 3phase RF filter box.
    Attachment 23126
    Attachment 23129
    Just a pure guess but they could be part of the supply for an inductive heating setup.
  2. #292
    Just tought of something..
    I'd you have the limitswitch like that and get some overshoot you will crush the switch ;)
    I.e if the machine is on a rampage and go full speed into the side.. If you have the switch in a way so the machine will only touch the trigger but pass the housing of the switch it should stop in a few mm :D
    Make any sense?
    Yes that's a good point but the microswitches are cheap and hopefully will reduce the damage when 4mm later the gantry mount crashes into the BK12 fitting lol, I'll see what happens when I start running it I guess.
    Should order a selection of button and lever microswitches so I have spares to play with only got 1 left at moment unless I rob the tat off the printer but they're just shit.
  3. #293
    I'm wrestling with the pros and cons of different mountings of limits myself. Don't want to loose to much precious travel and don't want to cheap out so a crash will destroy something :)
    Because a crash or eleven will happen :D
  4. #294
    Almost, almost there switches are wired to the BOB now, I've took power from the PSU case to a connector block then split it 4 ways to the AM882's.
    Quick question my AM882's the power in is marked AC for both inputs which one is the + and which one the -?
    I'm using DC obviously.
    I have my water cooling feeds in/out installed, just got to connect the motors and the spindle and plug her in ;)
    e2a Just realised the alarm is wired wrong on mine, manual makes it confusing, will swap them over
  5. #295
    Lives in Plymouth, United Kingdom. Last Activity: 2 Weeks Ago Has a total post count of 1,748. Received thanks 299 times, giving thanks to others 11 times.
    Doesn't matter in this case - because the power inputs can handle AC or DC, you can connect the DC either way round.
  6. The Following User Says Thank You to Neale For This Useful Post:
  7. #296
    As Neale has said. But not all AM882 are the same I think you have bought them from different sources so check all of them. I think it is the AM882H that can handle AC or DC and the AM882 is only DC. As usual could be wrong.
  8. #297
    You right the AM882 are DC only they discontinued them now in favour of EM806 which I should have bought. Oh well think it'll be ok anyways ;)
    Next time going for a stepper motor, encoder, driver combo all round. Expensive but really the only logical choice.
  9. #298
    Morning, quick question.
    My PSU is in an old PC case when I run power from mains to the PSU can I drill a hole in the pc case add a bolt and nut then use a round terminal to connect the earth from the mains to the pc case to create a ground?
    Is this safe? I'm then going to bolt the PC case with the AM882's to the PSU's case so that's grounded and then I can connect the metal RF shielding from the CY cable to the am882's pc case and it's shielded.
    does this all sound good?
    Also how I understand it I do not ground the CY cable at both ends (In my case at the stepper driver end) is this correct?
    She's going to move today fingers crossed ;)
  10. #299
    No you have not. That is the beauty of a forum its generally self correcting I certainly need it. and I value your input.
    That's true it's a great forum but if you're a know it all kind of guy you better be right lol otherwise you're going to find out about it very soon, the one thing about this hobby is it's always a learning curve no matter where you are on the curve.
  11. #300
    At least the PSU works ;)
