Good work :D
Thanks for the reporting, many points made that can help others!
Im a bit envious about the side finish.. packingtape seems like the way to go;)
17-11-2017 #2
Dont envy me. :-)
I only showed the best of the results.
I will finish clean up and do some more pictures later.
All in all i am happy with the results.
MK II will be a hole in one
the acrylkit solution has a downside.
It weakens +/- 3 mm of the sides..
Ill draw up something to explain.
So when i want just epoxy on the sides i need to scrape some 3mm off.
this eliminated meniscus in the process.
And the nice and easy side finish is gone.
Use least possible kit seam.
On the pouring side of the siding that is.
Use rich kit seams on the outside.
Ok both my x axis are 1850mm long, the epoxy varies in thickness from 7mm one end, to 3 mm half way , other end 6mm
Equals 3.5 mm of warp by welding only.
I did not expect that.
1mm out of level by spirit level over 1850mm.. equals 0.5mm / meter error in spirit level... right on spec for expected spirit levelling accuracy.
ok.. looks like i have about 1830mm of flat surface for rail.. need to update BOM list spec for Fred.
Did any of you cut linear rail by angle grinder?
Grtz Bert.
22-11-2017 #3
30-11-2017 #4
BUILD LOG: First Build 5 x 12 Steel Frame CNC router
By Scott Damman in forum DIY Router Build LogsReplies: 104Last Post: 18-01-2017, 06:36 PM -
600x900 Steel welded router build
By embraced in forum Gantry/Router Machines & BuildingReplies: 7Last Post: 08-10-2014, 10:55 PM -
By ivars211 in forum DIY Router Build LogsReplies: 59Last Post: 28-07-2014, 08:29 PM
