Thread: My new 6040 improvement plan.
Yeah but in your example of the Z-axis bolted to the gantry, it can't pull away... a wheel isn't attached to the gantry it just rides on it. Sure it can't push into the gantry (well, beyond what degree flex of the wheel allows) but it can pull away from it. That's not even getting into the problem with swarf getting trapped under the wheels and wearing down the relatively soft aluminium surface.
What you need is something that can't push towards the gantry or pull away from it - ie a supported rail. Round supported rail however has the drawback that the shitty bearing becomes the weak point (even shittier than a fully round rail bearing is)... enter profile rail. Now you come full circle to what I was saying in the first place which is that the unsupported round rail is just inherently inferior to profile rail for milling anything substantial.
Honestly, what you are suggesting is a waste of time - imo the improvements will be minimal if noticeable at all. Combine that rear plate with proper linear rails and now you have a substantial improvement but are at the mercy of the next weak link. And onwards the chase continues.
Listen to me or don't, but I would sincerely suggest you just get cracking with your machine without any major effort/changes and take it from there. I would say after a few mods and chasing your tail you will come to the conclusion that it's better to just chalk it up to a good entry machine for learning/playing around and decide to build your own one rather than constantly trying to work around the inherent weaknesses of the design. Either that or you will decide that for whatever your intended purpose is, it's just fine.
Note that when I say the inherent weaknesses of the design, I'm not just talking about the unsupported rails... there are MANY issues with these machines and to address them all you would effectively end up building a new machine anyway - which is what I am now doing myself.
Just trying to save you some time and money in the process. Up to you if you want to heed that or not.Last edited by Zeeflyboy; 17-12-2017 at 10:52 PM.
17-12-2017 #2
I see what you mean about it moving away from wheels, but that would take a lot more force and I don't see how it would happen. The workpiece can only push from the very bottom.
The supported rail was my plan, but I seen the guy on YouTube done it and it didn't help at all. Maybe with the fat backplate though. The way the ballscrew is attached to the bearings just now make it look like a big job. I'll need to have a good think how to do it though.
BTW, I'm still using the machine in between mods. I did specifically buy it with intention of modding it and learning. I knew the weaknesses when I bought it, if anything it was a lot better than I'd expected. I didn't get disappointed. It's a hobby machine. I'm hobbying.
17-12-2017 #3
I think you underestimate how little it takes to produce chatter
Again, the supported rail that you are thinking of is not what I suggest. Supported rail is barely better than round rail... What I am suggesting is profile rail. Everything else you do without doing that is just really little more than pointless.The supported rail was my plan, but I seen the guy on YouTube done it and it didn't help at all. Maybe with the fat backplate though. The way the ballscrew is attached to the bearings just now make it look like a big job. I'll need to have a good think how to do it though.
Good, and I applaud garden shed engineering - it's quintessentially British. Even so, there is limited value in repeating the mistakes of others that have gone before you. One of the great things about our species is the ability to progress based on prior learnings of others rather than being doomed to constantly be stuck in a cycle of repeating the same failures... There is a reason why anything above the absolute most entry level machines use profile rail across hobby/industry and it's not because they weren't creative enough to come up with weird and wonderful solutions like wheels.BTW, I'm still using the machine in between mods. I did specifically buy it with intention of modding it and learning. I knew the weaknesses when I bought it, if anything it was a lot better than I'd expected. I didn't get disappointed. It's a hobby machine. I'm hobbying.
17-12-2017 #4
Okay, I'll look at profile rails.
In your opinion, what are the Chinese profile rails like? Their prices look fine, but most of the branded ones I've seen are just far far too much for me.
17-12-2017 #5
17-12-2017 #6
https://www.ebay.co.uk/itm/15-1500mm....c100011.m1850
This is what I used on my gantry I'm very happy with it
You could buy a set of 1500mm with 4 carriages and a set of 300mm with 4 carriages for £200 and then cut the 1500mm down to get the usable lengths of rail to fit X&Y and swap the carriages across.Last edited by Desertboy; 17-12-2017 at 11:41 PM.
The Following User Says Thank You to Desertboy For This Useful Post:
17-12-2017 #7
They certainly aren't expensive, thanks!
I'll look over the machine and see what the options for mounting are. A big fat back panel will certainly be needed.
Thanks again.
17-12-2017 #8
Seems people have got on fine with Noulei from what I've seen... it'll still be an order of magnitude better than round rail either way. Some good sellers on Aliexpress (I've bought HIWIN there before and been very happy) that will supply to your specs.
Have at least a rough plan though before ordering anything, and do bare in mind that you are addressing one of many mechanical weaknesses in the design... so if the plan is to continue to mod this particular machine, worth having a plan of what comes next and whether that will affect your mods here. For example, to change to profile rail you will likely have to make a new Z-plate and spindle mount. Is it worth changing that over to profile rail as well to avoid having to change it twice? Now your supported rails on the Y-axis are a weak point, then the ridiculous floppy bed, then the thin bendy gantry arms, then the piss poor use of retaining bearings for the ballscrews etc etc.
You see what I mean I hope... Just think it all out (almost like a new machine design) before committing to buying anything.
Then once you've done that and other mods, now you have semi respectable rigidity and realise your extrusions aren't straight enough... at best out come the shims, at worst another redesign. Then you decide you could have done a better job just designing from scratch. It doesn't end :)Last edited by Zeeflyboy; 17-12-2017 at 11:44 PM.
The Following User Says Thank You to Zeeflyboy For This Useful Post:
17-12-2017 #9
I have original Hiwin's on my Y axis and the clone rail on my X axis they feel identical to me.
That clone rail I linked to is in Germany so no import tax and only took 3 days for delivery for me although will be slower at the moment of course.http://www.mycncuk.com/threads/10880...60cm-work-area My first CNC build WIP 120cm*80cm
17-12-2017 #10
At some point it makes more sense just to use it as it for 6 months and then sell it as is and build your own from scratch using the lessons learned along the way.
I bet you'd have no problems selling it for what you paid for it as bad as it might seem it's still better than an xcarve or shapeoko so plenty of potential users out there.http://www.mycncuk.com/threads/10880...60cm-work-area My first CNC build WIP 120cm*80cm
New 6040 owner looking for advice from others with a chinese 6040/3040
By itsmillertime in forum Machine DiscussionReplies: 12Last Post: 14-10-2019, 08:30 AM -
NEW MEMBER: Hi all, Ive got a plan, hopefully its a good one!
By Benja in forum New Member IntroductionsReplies: 6Last Post: 25-06-2016, 12:58 PM -
Mach 3 Driver test results & improvement
By Joe in forum Artsoft Mach (3 & 4)Replies: 15Last Post: 15-12-2013, 11:53 AM -
NEW MEMBER: Designer with a plan looking for advice
By bigstu67 in forum New Member IntroductionsReplies: 2Last Post: 10-10-2012, 06:04 PM -
So... what do you plan to do over the hols?
By irving2008 in forum General DiscussionReplies: 5Last Post: 23-12-2008, 09:03 PM
