    They'll be ok for what I want to use them for, not positional accuracy lol.
    Started on my clamps
    the 2 pieces will be bolted together with M4's a T nuts, then the ends drilled for M6 so I can bolt into T nuts in the 10mm track. Idea is I'll have 2 flat surfaces braced and all 4 corners. So I'll make 2 of these cost from KJN £35.
    Will only work for rectangular stuff but that 100% of what I want to cut ;)
    I ground the corners so they would sit flat when supporting the piece. They're adjustable of course so you can support any size piece and they work over the whole travel of the machine. Might add some toggle clamps.
    Now I need a good table saw to prepare the wood on.
