    Well, here is what I ended up with:
    Sorry the 2nd pic is rotated (again) - but I think I figured it out now that I have one that is and one that isn't...
    Anyway, I am thinking of an adjustable tensioner. Seems like a long span there on top - you guys think that'll be a problem? I really have no experience with timing belts like this.
    Thanks,
    Wallace
  2. The Following User Says Thank You to wallyblackburn For This Useful Post:
  3. #2
    Quote Originally Posted by wallyblackburn View Post
    Thanks,
    Wallace
    Hey Wally!
    I have no experience with such long belts, but I can imagine that the top part will flap if going fast?
    A tensioner on top might be a good stabilizer ;)
    More importantly is that a Mustang in the rear of the photo? Camaro and Firebird man myself but could slum it with a mustang whilst I wait for a 67SS to drop from the sky or a 77 Trans Am ;)
    The commercial printers we scrap always have tensioners on and the belt lengths are measured in inches (Short), if you can get tensioners easily enough than I'd fit them. They're sprung to apply constant tension and are adjustable.
  5. #4
    It is actually a '65 T-Bird. I went to an auction with the intention of buying a '63 Impala SS, and somehow came home with that over-engineered POS. Auction fever, I guess!
    I think I will try to fab up a tensioner for the top span.
    Regards,
    Wallace
  6. #5
    Lives in East Lothian, United Kingdom. Last Activity: 23 Hours Ago Forum Superstar, has done so much to help others, they deserve a medal. Has a total post count of 2,992. Received thanks 376 times, giving thanks to others 9 times.
    I'd try the setup as is. The worst case scenario is the belt flaps far too much and causes resonance problems, and you then have to add some idler pulleys.
    If it does need a couple idlers added, I would probably add a couple rollers to the top, to drop the belt down in the middle and increase wrap on the ballscrew pulleys.
  7. #6
    Rigged up a tensioner using stuff on hand - including a Subaru timing belt idler bearing:
  8. The Following User Says Thank You to wallyblackburn For This Useful Post:
  9. #7
    First movement!!!
  10. The Following 2 Users Say Thank You to wallyblackburn For This Useful Post:
  11. #8
    First movement!!!
    I don't think it will cut anything without a Z axis
  12. #9
    First movement!!!
    Thats not movement that's a twitch.!. . . . Let it have it's head to shake the gremlins out.
  13. #10
    Be careful not to over tension because will deflect the ball screws causing whip when at opposite end of travel. It would have actually been ok without a tensioner thou it's better down out of the way.
  1. "Hacking" and "Modding"
  2. Cnc router wood "roughing bits" anyone used these before?
    By gavztheouch in forum Motor Drivers & Controllers
    Last Post: 27-04-2014, 10:11 PM
  4. "Racks" VS "ball screw"
  5. BUILD LOG: Planning and build of my "8020" aluminium CNC Router
    By monza in forum DIY Router Build Logs
    Last Post: 06-02-2010, 11:55 PM
