    Hi Guys,
    Where do you all buy the West systems Epoxy and hardener from and is there a handy calculator for how much I need? I have looked in the manual but it mentions volume with use of fillers which I wont be using. I just want to make sure I order the right amount as this stuff ain't cheap.
    Cheers,
    Charlie
    Quote Originally Posted by CharlieRam View Post
    Hi Guys,
    Cheers,
    Charlie
    Hi CharlieRam,
    I guess west systems is proven route.
    I was unable to get west systems tropical hardner so i looked for an alternative.
    I found 3kg at 75 something euros
    6 hrs pot life at 21 celsius.
    About the same end strenght/hardness.
    I found that the thicker the film was the harder it was to delaminate it from the steel.
    I ended up pouring 5+mm thick 6 cm wide.
    so a simple length x width x height will calculate volume.
    I have a 185 cm x 100cm bed and ended up needing about 2.7 liter ~ 2.7kg.
    i used 2m extra leveling channels.
    so about 7.5 meters of 60mm wide 5+mm deep epoxy
    I made an error during last pour and had to do it all over... so.. bought 6 kg in total.
    Hope that helps.
    4cm width 4mm thick is the minimum for 20mm rail as can be found on this forum.
    Grtz Bert.
    Quote Originally Posted by driftspin View Post
    Hi CharlieRam,
    Hope that helps.
    Grtz Bert.
    Thanks Bert
    So it's 1kg to a litre? That's what I was thinking. So my channels are 40mm x 1350mm plus 2 channels to connect them at 40mm x 800mm. Say I go for a depth of 6mm epoxy that comes out at 1.032 litres.
    Ideally I want to go for the wests but I can only seem to find the 209 in 1.45kg which is way too much. If it's 3.5:1 mix ratio then I should only need around 1kg of resin and 250g of hardener.
    The 209 seems to be very unpopular in the UK though!
    Sent from my SM-G950F using Tapatalk
    Lives in Marple Stockport, United Kingdom. Last Activity: 10 Hours Ago Forum Superstar, has done so much to help others, they deserve a medal. Has a total post count of 3,346. Received thanks 618 times, giving thanks to others 87 times. Made a monetary donation to the upkeep of the community. Is a beta tester for Machinists Network features.
    The System that we seem to use over here is the Wests System 105 / 209 http://www.westsystem.com/ss/use-guides/
    it is a very slow curing hardener about 10 hours but you have to be careful with the temperature.
    https://www.ecfibreglasssupplies.co....t-system-epoxy
    That link you posted doesn't seem to have the 209 either! The only place I've seen it listed only has the 1.45kg tin and I don't want to buy a big one as it's just a waste. I may have to price up importing it. I just don't understand why the 209 is so hard to get when all the others seem readily available.
    Cause .. we dont live in the tropics i guess :-)
    Grtz Bert
    its where I bought mine from but that was a few years ago.
    edit try here:- https://www.boatpaint.co.uk/acatalog...eners_213.html
  8. The Following User Says Thank You to Clive S For This Useful Post:
  9. #8
    checkout dansonmarine on ebay.
    https://m.ebay.nl/itm/282845732420
    They stock it sometimes.
    Grtz Bert.
    1.3 kg A Pack
  10. The Following User Says Thank You to driftspin For This Useful Post:
  11. #9
    Cheers Clive and Bert, Clive that was exactly what i was looking for :)
    One more thing...... Can you check my calculations to make sure I'm right
    2 rails 135cm x 4cm wide + 2 bridges @ 77.5cm x 4cm with depth of 6mm
    (135+135+77.5+77.5)X4X0.6 = 1020cm3 = 1.02 Litres
    1.02 Litres / 4 = 0.255 Litres 209 Hardener
    @3:1 ratio by volume = 0.765 Litres of Resin.
    Seems the weights are not quite 1 litre to 1 Kg as the manual states the ratio is 3.5:1 by weight.
    Regards,
    Charlie
  12. #10
    Regards,
    Charlie
    Are you doin a aluminum profile gantry
  1. Self levelling epoxy resin
    By flanagaj in forum Gantry/Router Machines & Building
    Last Post: 21-11-2020, 01:47 AM
  2. Use of epoxy for levelling
    By Neale in forum Gantry/Router Machines & Building
    Last Post: 25-08-2019, 04:21 PM
  3. epoxy question
    By driftspin in forum Gantry/Router Machines & Building
    Last Post: 24-06-2017, 01:44 PM
  4. Sand and Resin Filling Box Section
    By grain_r in forum Gantry/Router Machines & Building
    Last Post: 16-12-2015, 08:45 PM
