Page 17 of 18 FirstFirst ... 715161718 LastLast
  1. #161
    If that is real CF, be careful of the dust and fibres...
    Messes up electronics, gunks up bearings, wears down rails and will do a number on your lungs. Even a vac with HEPA filter can let some through... best option really is to cut it underwater if you can.
  2. yeah its the real stuff as thats what I make, ive put the machine into an enclosure to contain the dist, making a better enclosure soon with a built in extraction system which should help
    Enthusiastic with CNC stuff but a proper novice so be gentle
    My build blog:
    Chinese 3020t Build
  3. #163
    I used to do a bit of work with a company designing drones, we started prototyping CF frames in their lab using a vac boot and a hepa filter.
    A few months after that, they had a hell of a time figuring out why their pcbs for flight controllers weren’t working as intended. Turns out the little carbon fibres had escaped and were wreaking havoc all over the lab.
    They had a top to bottom clean and switched to cutting in a water tray so that the CF is submerged. No problems since.
    Worth thinking about if you’re going to be doing a lot of it.
  4. I will look into that, but im mainly going to be machining resin billets
    My build blog:
    Chinese 3020t Build
  5. Right chaps,
    had a bit more time playing with the machine, ive got the motion speed set pretty low, feed rate set at 200. But it seems to be struggling with right angles and sharp points, it seems to add a small radius in these areas even though on the preview on the software there are clear points.
    Any ideas?
ID:	24400Click image for larger version.
ID:	24401Click image for larger version.
    My build blog:
    Chinese 3020t Build
  6. #166
    Google Mach3 Constant Velocity
  7. The Following User Says Thank You to Doddy For This Useful Post:
  8. Just had a quick read, ive now changed the motor speeds in my planet software from 500 to 200
    seems to have sorted it i think, bloody slow now though lol
    My build blog:
    Chinese 3020t Build
  9. #168
    Quote Originally Posted by ravihotwok View Post
    Sorry, missed that you was using Planet CNC software. Check this out http://forum.planet-cnc.com/viewtopic.php?f=5&t=1271 (no promises!)
  10. managed to speed up the motors to 500, but changed the blend value to 0. Machining fine now, but a bit stop start on curves
    My build blog:
    Chinese 3020t Build
  11. not much of an update but ive begun sourcing parts for the new extraction system and also the new enclosure. Ive tidied up my tool bench and moved it from the back wall against my booth which has free'd up some more space. Also got a big screen dedicated to the cnc stuff
    I have made some small holes for the machine wires to drop neatly through the base of the enclosure so it is nice and neat, will be going to screwfix later to pick up some odds and sods for the extraction system. Im happy with the setup so far :-)
    My build blog:
    Chinese 3020t Build
  1. 3020T Capabilities
    By TT901 in forum Chinese Machines
    Last Post: 03-03-2017, 04:20 PM
  2. Chineese 6040 problems
    By Kendrick57 in forum Gantry/Router Machines & Building
    Last Post: 18-10-2015, 10:52 PM
  3. Ballscrew for 3020T Y Axis
    By richie00boy in forum Lead Screws, Nuts & Supports
    Last Post: 02-08-2013, 02:47 PM
  4. A viable mini-ish-mill build, or a hiding to nothing..?
    By Wal in forum Milling Machines, Builds & Conversions
    Last Post: 02-07-2013, 07:33 PM
  5. Replies: 18
    Last Post: 04-06-2009, 03:44 PM
