Page 25 of 35 FirstFirst ... 152324252627 ... LastLast
  1. #241
    The mail man drop a package this Tuesday !
  2. #242
    Hi Nick,
    You just made me regret not buying a UB1.
    Keep up the good work!
    Grtz. Bert.
  3. #243
    Sorry Bert,I didn't have this intention!
  4. #244
    To much heat at the workshop this time of year,so I am going to start the electronics wirring .
    Any diagram to follow?
  5. #245
    Wooohooo :D
    Nice!
    Also good to see progress. I like the motormount, how did you cut it ? :)
    About the circuit diagram.. do you want minimal but good or somewhat more elaborate?
  6. The Following User Says Thank You to Nr1madman For This Useful Post:
  7. #246
    I was lucky with the motor mount ,I just too advantage of the one end of the heavy duty aluminum beam,it was made like that and I cut it with the grind cutter.
    About the diagram I want some thing that will work and not burn any driver or something else,haha
  8. #247
    I followed this schematic
    Its made by a forummember "euricain" I Think..
    Then there is this from jazz
    And I also found lots of inspiration from this. I think it was routercnc that made this one..
  9. The Following User Says Thank You to Nr1madman For This Useful Post:
  10. #248
    Thanks Robert.
    I had the number one and number three schematic,thanks for the second one.
    Can I ask why you follow the first schematic?
  11. #249
    Thanks Robert.
    Yes the last one is mine. Since then I’ve changed the Z drive to DQ860MA to match the others and run off the 68V supply. That allowed me to remove the 30V supply.
    As my new Mk4 machine uses 2 Z steppers I’ve added another DQ860MA drive off the same supply so there are 5 drives in total. Otherwise all the safety relays and interlocks are the same. Works well.
  12. #250
    Thanks Robert.
    I was set on using the schematic from jazz since I started my build.
    Then I read the thread about the first I posted and thought it made sense..
    The one from routercnc has alot of extra benefits like bleed resistor and ability to change vfd speed manually.
    But I still went with the first :D
  13. The Following User Says Thank You to Nr1madman For This Useful Post:
  1. cnc 4axis hot wire mach3;
    By maikonesk in forum Hotwire Cutting Machines
    Last Post: 07-08-2015, 02:15 PM
