30-06-2018 #10
Is this any help? I wire up the Z steppers towards the end of the video.
https://www.youtube.com/watch?v=UQVooJ1aURM
About 25:40 time stamp
I started by trimming the motor wires as short as I dared as this last part is not shielded. I’ve not seen anyone run the shield right to the motor. May get a ground loop if the machine is also grounded ? Not sure.
BUILD LOG: First Build 5 x 12 Steel Frame CNC router
By Scott Damman in forum DIY Router Build LogsReplies: 104Last Post: 18-01-2017, 06:36 PM -
600x900 Steel welded router build
By embraced in forum Gantry/Router Machines & BuildingReplies: 7Last Post: 08-10-2014, 10:55 PM -
By ivars211 in forum DIY Router Build LogsReplies: 59Last Post: 28-07-2014, 08:29 PM
