This is perfect but cant get a response from the seller - https://london.craigslist.co.uk/tld/...611374089.html
11-07-2018 #2
11-07-2018 #3
Id buy this but its too tall and probably needs more power than I can provide.
https://www.ebay.co.uk/itm/Bridgepor....c100005.m1851
11-07-2018 #4
Nice to have full enclosure! When you run full coolant and decent toolpaths, you get stuff everywhere.
There is also a Taiwanese VMC on ebay similar price, possibly better quality and condition, less well known.
You would run these off a VFD. Usually only the spindle needs 3 phase and you can run the coolant off single phase with a motor run cap to create the 3rd phase. The other stuff in the cabinet can usually be rewired for single phase without too much buggerage. And if you need to restrict the max power draw, you can change the VFD parameters or worst case get another VFD where you can do that. If you are drawing 10HP you will be shifting some serious swarf, so dialling it back to a few kW won't be a big issue.
11-07-2018 #5
Yep. Are you talking of this machine? I cant find any specs for it ... https://www.ebay.co.uk/itm/TRYAX-B5A...kAAOSwivNbO2fM
There is also this, no specs that I can find - https://www.gumtree.com/p/other-powe...26159?srn=true
11-07-2018 #6
I was talking of this but now I look again it's the size of a bus. https://ebay.co.uk/itm/DAH-LIH-MCV-1....c100005.m1851
The second one looks like a classical Bridgeport based machine but a proper CNC system from new. Might be OK but has only 5" quill movement and no enclosure(!).
Quite a few nice looking VMCs on Craigslist around the £5-6k. Didn't know Craigslist had become so established over here. It's the default marketplace over in Canada / US - must keep an eye on it now I'm back in UK.....
11-07-2018 #7
That Tyrax looks pretty nice but as a non-runner the price seems a bit high. Perhaps you should offer half of that and see if they bite. They obviously don't think it's worth fixing it themselves...
The Centroid controller should be OK to work with. The issues are likely to be with the spindle and drive (at least). Could be a risk hence don't offer too much. Who's going to pay £3k for it?
11-07-2018 #8
Milling machine CNC conversion - keep hand wheels for manual operation?
By birchy in forum Milling Machines, Builds & ConversionsReplies: 5Last Post: 23-10-2016, 08:29 PM -
Manual autochanger problems.
By Saracen in forum Lathes, Lathe Rebuilding & ConversionsReplies: 1Last Post: 05-02-2015, 01:14 AM -
WANTED: Centec 2A manual
By Web Goblin in forum Items WantedReplies: 0Last Post: 03-09-2012, 09:56 AM -
Translating the manual
By Robin Hewitt in forum Moulding MachinesReplies: 22Last Post: 01-09-2012, 01:21 PM -
Bridgeport Conversion
By Tony Goodwin in forum Bridgeport Milling MachinesReplies: 0Last Post: 08-08-2011, 08:11 AM
