    sorry i have not been back in touch my internet was canceled and i have just got it back up and running.
    the voltage is of my Arduino which is 5v but i have heard that if you run the Mega you can use 12v
    again my apologies for not getting back to you when you was kind enough to answer. not me at all
    ps the vfd is plugged into a five way adaptor the long type
    Again thanks
    The motors, spindle, and VFD all put out quite strong and varying magnetic fields, which induce small voltages in the cables around them. The VFD can also pump electrical noise back into the mains supply, which can also cause problems.
    As magicminer says, you can use shielded twisted pair cable for your E-Stop line which should help to reduce the influence of the inducted noise.
    Magicminers other suggestion was to put more cable distance between the VFD and the control system power supply, which will slowly attenuate the noise. A 5-way plug doesn't really do anything - its cable length, and if possible filtering, that will impact this.
    At the moment, your signal is probably on (2.5V-5V) or off (0-2.5V) - meaning the noise only has to be ~ 2.5V to cause major headaches. If you increase the voltage on this line to 12V, the noise has to be on the order of 6V to cause the same problems. If you have an oscilloscope, you could measure what the level of noise is.
  3. The Following 2 Users Say Thank You to AndyUK For This Useful Post:
    i have been told that i need to put a 100nf capacitor as per the diagram and that should work,
    thanks for the help i will get some two core shielded cable as well.
  5. #4
    Quote Originally Posted by Slasher102 View Post
    Hmmm, Mega = Arduino Mega?, based on the AT MEGA 2560 MCU, still runs at 5V, but the on board regulator will provide the 5V required by the MCU. The I/O remains, however at 5V. AndyUK touches on ways to improve noise immunity, but with an Arduino-based system (and 5V logic) your best bet is to use opto-coupled inputs with a 12V (plus) input drive system onto the optos. The Arduino as-is is likely to be susceptible to noise.
  6. The Following User Says Thank You to Doddy For This Useful Post:
  1. Setting up new spindle
    By Hercules in forum Generic Chinese Spindles
    Last Post: 10-12-2019, 01:18 AM
  2. What is the best way to Test a chines machine?
    By cnclover in forum Chinese Machines
    Last Post: 27-07-2019, 07:13 AM
  3. setting axis A in spindle mode
    By ladybreaker in forum Artsoft Mach (3 & 4)
    Last Post: 09-12-2018, 11:35 AM
  4. Chines CnC ebay
    By amxen in forum General Discussion
    Last Post: 01-02-2015, 03:46 PM
  5. setting up Moeller VFD to chinese spindle
    By routercnc in forum Spindles & Drive Motors
    Last Post: 16-02-2011, 08:22 PM
