Page 9 of 10 FirstFirst ... 78910 LastLast
  1. #81
    Knowing now that its never worked for you then You need to go back to basics and just get the machine talking to mach3 So it moves the axis.
    That board is a spindle board and won't affect anything but the spindle so dont worry about that now.
    In it's basic form all you need to get machine moving is to connect drives to Bob and provide power. Limits', e-estop and everything else can be left disconnected.
    Then in mach3 just set correct step n direction pins for each drive in motor outputs. You can ignore any input/outputs as they only apply if being used. you will have to toggle estop active high/low so mach resets.
    When you have movement then you can start putting the limits etc back into use.
    Trying to trouble shoot a machine you know nothing about is like fubbling around in dark. Better to just start again at the beggining.
    Sent from my SM-T580 using Tapatalk
    I’m abit lost sorry - I thought the bob was the issue? The machine has worked, I’ve used it for about a year- the problem came after moving it.
    Would I be correct to say I need a new bob and motor drivers?
  2. #82
    Never mind I wrote something after skipping a few pages.... :/
  3. #83
    No stress mate- would something like this be any good?
    https://rover.ebay.com/rover/0/0/0?m...2F401808748123
  4. #84
    Quote Originally Posted by IhateDoug View Post
    No. Unless you really want/need to make an upgrade. I doubt you have fried your motor drivers.
    Could you start again troubleshooting the signal, starting from your computer?
    First measure the parallel port pin output voltages to see if mach3 outputs signal when you send commands and if this signal is 0-5 volt. If not, there's a problem on the computer side. It could be mach3 parallel port driver, computer power management, bios settings.
    If mach3 is transmitting and receiving 5v signal through the parallel port then most probably the BoB is the problem.
    If you need more detailed assistance in checking the signal I can try to give you a step by step guidance.
  5. #85
    This is my point. If all you did was move the machine which worked before the move then it's highly unlikely that the Bob or Drives are broke. Worst case you'll have lose or broken wire.
    The fact you changed the pc gives much higher chance your problem lies here.
    It's certainly the first place should be looking and testing PP is working.
    Regards the machine itself then it's very basic machine so won't be difficult diagnose any fault. However first need know exactly what you have in control box. Or better put how hacked up it's been from standard.?
    In it's basic form to get movement all you need is power for bob and drives and signals from PP. Everything else can be left disconnected and replaced at later time when got movement.
    Show us pics of inside control box and each of the boards.
    Email: [email protected]
    Web site: www.jazzcnc.co.uk
  6. #86
ID:	26337Click image for larger version.
ID:	26336Click image for larger version.
ID:	26335Click image for larger version.
ID:	26334Click image for larger version.
ID:	26333Click image for larger version.
ID:	26332Click image for larger version.
ID:	26331Click image for larger version.
  7. #87
    Also noticed these
ID:	26338Click image for larger version.
  8. #88
    Oldy's Avatar
    Lives in Lincoln, United Kingdom. Last Activity: 16-11-2019 Has been a member for 5-6 years. Has a total post count of 6.
    I am having a nightmare trying to get an old system running that has been stalled for 18 months.
    I had similar ‘nothing doing’ issues, until I found that the pc comma port was NOT set up as a EPP.
    Check this in the bios. I had to hold F1 key on start up and then set the port to EPP (enhanced parallel port)
  9. #89
    Also noticed these
    If they aren't modifications made since it last worked then they should be ignored as it ran fine like that previously?
    It's not uncommon for manufacturers to correct a faux-pas on a board with a wire link ;-)
  10. #90
    Ok nowhere do I see a Parallel port cable but I do see an Ethernet Cable going to what looks like a Controller board with ribbon cables going to Breakout board so are you sure it's using Parallel port.?
    If it's using Ethernet then it won't work untill you set the Ethernet address and it would be Dead just like your experiencing.!
  1. syil x4
    By geoff in forum Machine Discussion
    Last Post: 30-11-2016, 07:35 PM
  2. FOR SALE: For Sale Syil X7 plus CNC Milling machine
    By dpcwright in forum Items For Sale
    Last Post: 13-09-2015, 02:27 PM
  3. Syil x4 or x5 as CAD/CAM training 4 axis CNC machine ???
    By towdi.arek in forum Marketplace Discussion
    Last Post: 20-07-2013, 07:26 AM
  4. What i am doing wrong with mach3?? trying to config machine.
    By scnc in forum Artsoft Mach (3 & 4)
    Last Post: 31-01-2013, 05:01 AM
  5. thinking about this Syil X5plus CNC Milling Machine with 4th Axis
    By Dellboy in forum Marketplace Discussion
    Last Post: 22-04-2012, 05:52 PM
