Page 13 of 33 FirstFirst ... 3111213141523 ... LastLast
  1. #121
    It could be aliasing from reflections on the lens holder thread, I got much better results with the sensor mounted with nothing close to it in the near field. See picture below, that window started off as a 6mm round hole, it caused aliasing hence I opened it up so no reflected laser light could hit the sensor.
    I don't know much about dslrs but maybe it could have lens distortion correction built in which would be warping the image non-linearly across the sensor. Have you got a cheap web cam to try with? It is also unlikely that sensor pcb is hard fixed to the body, the ones i've take apart are usually on soft mounts that let the board move around to absorb shocks.
  2. #122
    It's cheap Sj4000 clone distortion is massive, if there is correction it does very bad job. I have cheap webcam and 0.08mm steel wire on order. Will try both laser and wire to rule out sensor nonlinearity errors.
  3. #123
    Quote Originally Posted by Sasquatch View Post
    One other thing that occurred to me, how did you ensure you moved the sensor/vice assembly absolutely in a straight line? Any deviation in this procedure would show up as non-linear errors in your linearity measure since it would have been impossible to get the laser perfectly planar with the granite. This applies to both types of laser dot and line. I think you need a precision straight edge as well as the reference surface to check the accuracy of the system.
  4. #124
    Quote Originally Posted by devmonkey View Post
    I used straight edge clamped to the granite, just as you said.
    Cheap webcam arrived, useless with lasers, sensor is smaller than the beam, will test it with wire when it gets here.
  5. #125
    Sounds like your laser is no good, can you post a picture of it? Even my dewalt laser level produces a line narrower than the VGA sensor.
  6. #126
    Greetings from NorthWest England
    I was alerted to this very interesting project by John McNamara [many thanks, John] and have joined the forum to participate in this discussion. ... Hopefully I can be of some help on the optical side of things, but this first post concerns the software:
    I have tried running the current version on my 2009 MacBook Pro, under el Capitan, and everything seemed fine except that I could not close the application ... it did not even respond to ‘Force Quit’ and I was obliged to re-boot the machine.
    Windows users have a .bat file; so I am wondering if some ‘initialisation’ might be required before Java is happy running the application under OS X
    I would be most grateful if anyone can advise.
    MichaelG.
  7. #127
    Hi Michael,
    Welcome! I haven't tried it under OSX, but I'm pretty sure someone in this thread did.
    It might well be a driver issue with it not unloading properly, unfortunately I don't have a mac book pro old enough to replicate your system.
    Joe
  8. #128
    Thanks for the prompt reply, Joe
    Hopefully there is someone else out there, limping along with a much-loved but obsolete Mac !
    MichaelG.
    Edit: I’ve just tried a little ‘self-help’ and found this:
    https://apple.stackexchange.com/ques...vents-shutdown
    Unfortunately it is beyond my comprehension.
  9. #129
    Quote Originally Posted by Michael Gilligan View Post
    As far as I can see, that's just talking about the issue and other ways to force quit the application.
    I'd try uninstalling and reinstalling java on your Mac.
    Failing that, you could try running Linux in a virtual machine, and download Java onto that. I'm a fan of Oracle's Virtualbox.
  10. #130
    Thanks, Andy
    I will try a clean install of Java this evening
    ... There have been several versions on my Mac over the years, so perhaps there is something unnecessary lurking.
    MichaelG.
    Edit:
    I removed all trace of Java from the machine [following Oracle's instructions], and installed afresh:
    ____ You have the recommended Java installed (Version 8 Update 231) ____
    For whatever reason: The application now closes as it should. ... Thanks again, Andy
  11. The Following User Says Thank You to Michael Gilligan For This Useful Post:
  1. WANTED: K40 laser
    By dfox1787 in forum Items Wanted
    Last Post: 23-10-2018, 08:34 PM
  2. Newbie - Help With Laser Cutting Speed And Power - 60W Laser
    By nickpscott in forum Laser Machines & Building
    Last Post: 11-11-2015, 10:07 PM
  3. FOR SALE: K40 laser not working (laser fires)
    By calida in forum Items For Sale
    Last Post: 31-03-2015, 08:45 PM
  4. WANTED: GCc Laser Pro or Epilog Laser Cutter Machine
    By Brownhills school in forum Items Wanted
    Last Post: 10-05-2012, 04:30 PM
  5. help with cnc laser
    By swinds in forum Laser Machines & Building
    Last Post: 09-01-2012, 10:15 PM
