Page 18 of 23 FirstFirst ... 81617181920 ... LastLast
  1. #171
    No need to have the motor connected. I usually only connect the motor once i have programmed the drive and tested the "settings". Most important thing is to make sure you have the motor connected properly
  2. The Following User Says Thank You to ericks For This Useful Post:
  3. #172
    Quote Originally Posted by Leadhead View Post
    Hi - Guys
    Just setup the wiring for standard Huanyang 2 .2 spindle and VFD.
    About to sort settings for VFD. Some info suggests not to power up the VFD without the spindle connected.
    Which is correct please. With spindle connected or without.
    really dont need to smoke anything at this stage!!
    There is no problem with starting the VFD with the spindle disconnected .BUT don't ever disconnect the spindle with the VFD running.
    Always make sure you fasten (clamp) the spindle cable to a fixed point so that the plug does not move, as a bad connection in the plug or a spark WILL give you a fright and release some money from your wallet
  4. The Following User Says Thank You to Clive S For This Useful Post:
  5. #173
    Another thing to remember is to use the correct cable between the drive and motor. I just repaired a machine where the original builder used microphone cable (2.2 Kw Hy water cooled spindle)...besides the fact it's not rated for the voltage imagine the under size re current!!! If you can't confirm the voltage rating of the cable then just don't use it :)
  6. The Following User Says Thank You to ericks For This Useful Post:
  7. #174
    Happened to document it....note also the soldering Click image for larger version.
  8. #175
    All up and running. Thank you gentlemen.
    One more ask :- How do I connect the 12v water pump to the VFD please.
  9. #176
    Hi Leadhead
    These are the 2 options I thought about
    1) Don't bother and have a separate connection for you water pump. Switch it on manually before starting the CNC/VFD. This is what I have done
    2) Or operate it through the break-out board on your cnc controller using a relay. You would then issue some Gcode to start the pump before the spindle start Gcode
    Hope this helps
    Mike
  10. #177
    Quote Originally Posted by MikeyC38 View Post
    Hi Leadhead
    Hope this helps
    Mike
    No need to do either of those as it's very easy to let the VFD operate it.
    There is relay built into the VFD which can be set up to turn on/off when spindle spins. By default it's set to operate when a fault occurs but with few parameter changes can be set
    for on/off.
    The relay connections are FB & FC just feed either the positive or Negative of the power going to pump through these terminals.
    Then change parameter for these relays to work when Fwd is pressed, I think the parameter is PD52 or 53 but not got the manual in front of me so I can not check.
    The relay then just becomes a switch to the pump.
  11. The Following 2 Users Say Thank You to JAZZCNC For This Useful Post:
  12. #178
    Hi Jazz
    As always the font of wisdom for us newbies. I forgot about these ports on the VFD. I was thinking about these to enhance my safety system by getting the relay ( based on your wonderful simple design emergency stop setup) to signal the VFD to stop when the safety button switch is operated.
    Mike
  13. #179
    I'm thinking of adding a slight enhancement to the "pump switched by VFD" thing by sticking a flow sensor in the return line to the reservoir driving a relay. It's then pretty easy to sound an alarm if the pump is energised but insufficient water's flowing.
  14. #180
    Hi Jazz
    Mike
    Yep, that would work and there are various ways it can be done, to be honest. The controller or Bob your using will also play some part in which approach to use.
    If I'm using a controller that doesn't have relays built into it then I control a relay for on/off using an Output. I then use this relay to turn the water pump on as well.
  1. Chinese Spindles
    By Ricardoco in forum Generic Chinese Spindles
    Last Post: 05-12-2016, 12:16 AM
  2. Info on Chinese suppliers, their reliability and reputation
    By Want2build1 in forum Marketplace Discussion
    Last Post: 07-12-2013, 09:37 PM
  3. NEW MEMBER: Seeking advice on a CNC setup for (one off) machining carbon fiber plate
    By Tomcat in forum New Member Introductions
    Last Post: 03-03-2013, 01:43 PM
  4. Chinese spindles
    By Colin Barron in forum Marketplace Discussion
    Last Post: 23-08-2011, 08:58 PM
  5. Chinese 1.5kw Spindles
    By jcb121 in forum Generic Chinese Spindles
    Last Post: 28-07-2011, 06:20 PM
