Hi Jazz
As always the font of wisdom for us newbies. I forgot about these ports on the VFD. I was thinking about these to enhance my safety system by getting the relay ( based on your wonderful simple design emergency stop setup) to signal the VFD to stop when the safety button switch is operated.
Mike
29-11-2019 #2
Yep, that would work and there are various ways it can be done, to be honest. The controller or Bob your using will also play some part in which approach to use.
If I'm using a controller that doesn't have relays built into it then I control a relay for on/off using an Output. I then use this relay to turn the water pump on as well.
Chinese Spindles
By Ricardoco in forum Generic Chinese SpindlesReplies: 123Last Post: 05-12-2016, 12:16 AM -
Info on Chinese suppliers, their reliability and reputation
By Want2build1 in forum Marketplace DiscussionReplies: 38Last Post: 07-12-2013, 09:37 PM -
NEW MEMBER: Seeking advice on a CNC setup for (one off) machining carbon fiber plate
By Tomcat in forum New Member IntroductionsReplies: 0Last Post: 03-03-2013, 01:43 PM -
Chinese spindles
By Colin Barron in forum Marketplace DiscussionReplies: 15Last Post: 23-08-2011, 08:58 PM -
Chinese 1.5kw Spindles
By jcb121 in forum Generic Chinese SpindlesReplies: 12Last Post: 28-07-2011, 06:20 PM
