They are bolted together from the bottom as mentioned in the last post and end plates are machined with L-shape pockets to match the profile then bolted to the ends to support the ends.
Yes, the first version I made used epoxy leveling until I aquired the large surface plate. Epoxy works ok it's just more work and takes a lot longer. The method I use now is dry within hours and can be drilled tapped the next day and rails fitted. You cannot fit rails on epoxy for at least 2 weeks.
Yes and no. Yes because the rails are not on the same plane so a little more work with a dial gauge to get parallel etc. However, it does offer other advantages regards setting up the Z-axis vertical tram because you can slide the rails back n forth ever so slightly if needed, plus you the X-axis top plate which can have a little adjustment in it. More adjustments the better when it comes to building a CNC machine but Obviously within limits so as not to put a binding on the linear bearings.
Where if you have both rails on the same plane and the Vertical tram is out then you have to mess around with shims or tilting the gantry etc. Worse still if the gantry as got any twist in it because then it's not so easy to get twist out. With rails on top you can take the twist out easier.
Yes, counterbore the slots to make a flat area for bolt head and then drill and tap into matching profile. Depending on profile type depends on how far into the profile I drill and counterbore.
Yes, it's a lot of fun and frustration at times. As for making money that's a different matter... Not so sure I really do at times...
04-02-2020 #2
Can you specify or maybe give me a link for the epoxy metal that dries so fast? I'd like to try that.
From where/how did you aquire the large surface plate and how much did it cost? I am thinking if it would be possible to make one DIY with epoxy resin, hehe.
Skickat från min SM-A530F via Tapatalk
04-02-2020 #3
They have many suppliers around the world I believe but this the company and the type I use.
https://www.belzona.com/en/products/1000/1111.aspx
It was gifted to me by a Friend. It's a massive 10" thick piece of fine-grained Granite that is precision ground to a calibrated tolerance and not something that could be replicated with epoxy.
You can buy them from any good tool supplier or meteorological supplier. However, they are expensive and very very heavy.
Some thoughts on cnc machine design principles. . .
By routercnc in forum Gantry/Router Machines & BuildingReplies: 15Last Post: 09-10-2020, 10:59 AM -
Q: 24V Line driver IC
By fabhund in forum General ElectronicsReplies: 13Last Post: 01-01-2015, 04:08 PM -
Does anyone know about CAD/CAM courses on-line?
By hoezap in forum Marketplace DiscussionReplies: 7Last Post: 04-12-2012, 12:26 PM -
Line fonts
By daveshorts in forum Computer SoftwareReplies: 4Last Post: 07-09-2010, 04:43 PM -
CamSoft is on-line
By CamSoft Corp in forum CAD & CAM SoftwareReplies: 1Last Post: 13-01-2009, 12:55 AM
